Background: I had a 3TB Seagate GoFlex Agent external hard drive full of media. I took off the enclosure and was going to use the 3TB hard drive in a new NAS (Western Digital ex4100) I purchased. I did not know at the time about the JBOD formatting needed for this NAS drive and incorrectly assumed that it would read my existing file type. As a result, I put the drive into the NAS and when it told me it needed to format my media drive to configure it, I canceled out properly and shut down the NAS properly, as well. I then removed the drive from the NAS; however, when I attached the drive to the original power supply and usb 3.0 adapter and plugged it into both mac os x and windows it was not able to see any partitions. In windows is shows the following two unallocated spaces (see pic below) and in os x it just asks to initialize the drive.
***Please note that at no time did I authorize or complete a format of this drive, so I'm hoping it is just a corrupt partition table or similar issue and I'm hoping to repair the partition rather than focus on file recovery strictly.
The hardest part that I have is I am not 100% certain of the files system I used and I've been reading but, don't have a 100% certain grasp of the technical terms regarding hard drives, volume, partition, etc. If I had to guess I probably formatted it to exfat in os x (which I now know is a big mistake), so that I could use the drive on both my PC and MAC. However, the drive could be HFS+ or NTFS, as well. I can't imagine I would have used any other file system.
Prior to finding testdisk, I used a trial of R-studio. Attached are some screen shots, in case they are helpful. However, I am more than willing to try out any instructions in Testdisk to first determine the format of my drive and then if we find that if we can repair the partition.
Thank you so much, in advance, for anyone willing to take time out of their day to attempt me to recover some previous files and photo memories. I would be happy to answer any questions or clarify anything that is confusing or run any other diagnostics in an attempt to recover my media.
Best Regards,
Jack
