Hi guys,
I'm having an issue with my brothers external harddrive.
He broke the usbport on the case, so I opend it and removed the HDD. It couldn't be accessed by an USB-to-SATA adapter so I attached it directly to the SATA port in my PC.
I wasn't able to access the drive with windows nor with ubuntu (live). Meaning that it wasn't accessible through the explorer, however it was listed under the disk management of Windows, whereas I was asked to reinitialize it. In a first try I DIDNT do that.
I tried testdisk, but couldn't recreate the partition.
I tried photorec but were only be able to rescue about 19 GB (from roughly 250GB) worth of manuals from Western Digital and about 5 *.gpg files with 3 GB each. Plus hundreds of 1KB *.txt, *.html and *.png files. From Western Digital as well I s'pose.
So I reinitialized it with Disk Management under Windows 7.
Photorec still recovers only manuals, *.gpg files and the others.
So I added a new volume (formated the drive) under Windows.
Same with photorec after that.
The whole thing is kinda strange!
Can anyone help? Or do I have to tell my brother the bad news that his data is gone?
Thanks a lot for any hint!
Cheers
Photorec only recovers manuals from external drive
Re: Photorec only recovers manuals from external drive
Windows initializing will only write a 4 Bytes signatur to your MBR/Partition table (also GPT) so that windows can handle your HDD.
Without initializing you cannot write your partition into your partition table.
This behavior is since W2k.
Somehow, a lot of people are afraid of, but I've had a certain amount of user where solved their problems after windows initializing successful.
Creating a partition after initializing and formatting should be avoided because testdisk can search for partitions instead and recover them.
The initializing message often appears if the MBR or GPT is corrupt or not available anymore.
But note, it's different to initalizing using any hardwarecontroller like RAID.
If RAID suggests to initialize, there is a possibility that a safe erase will override each sector.
Datarecovery wouldn't be possible anymore.
Creating a partition equalliy to your previous partition and formatting it will override your underlying file system.
In case you'll need datarecovery software.
If you're unsure or you didn´t format equally you can run testdisk / Aanlyse / Quick Search and if nothing would be found Deeper Search also.
You can select your found partitions and press p to have a try to list your files.
If you can list your data you can recover it.
If you only see an empty file system, your file system is probably overridden and you'll need datarecovery software.
Can you copy and paste the content of your testdisk.log into your next post?
Hi Fiona,
Last night I ran testdisk but I can't list any files (by pressing "p"). same by using Advanced / List files
Do you have any recommendation how to recover the data.
below the contents of the logfile.
Thank you for your help
Wed Jul 22 19:00:55 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=1000170586112
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=240155361280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000169537536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=499971522560
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512
Drive C: - 240 GB / 223 GiB - CHS 29197 255 63, sector size=512
Drive D: - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512
Drive F: - 499 GB / 465 GiB - CHS 60784 255 63, sector size=512
NTFS at 16/113/34
filesystem size 976506880
mftmirr_lcn 2
HPFS - NTFS 16 113 34 60801 47 46 976506880
NTFS, blocksize=4096, 499 GB / 465 GiB
file_pread(5,2,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,2,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,8,buffer,976773376(60801/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,976773504(60801/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,976773632(60801/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,976773760(60801/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,976773888(60801/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,976774016(60801/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,976774144(60801/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,976774272(60801/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,976774400(60801/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,976774528(60801/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,976774656(60801/104/40)) lseek err Invalid argument
file_pread(5,8,buffer,976774784(60801/106/42)) lseek err Invalid argument
file_pread(5,8,buffer,976774912(60801/108/44)) lseek err Invalid argument
file_pread(5,8,buffer,976775040(60801/110/46)) lseek err Invalid argument
file_pread(5,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(5,13,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(5,3,buffer,976775183(60801/112/63)) lseek err Invalid argument
file_pread(5,3,buffer,976775230(60801/113/47)) lseek err Invalid argument
file_pread(5,8,buffer,976775246(60801/113/63)) lseek err Invalid argument
file_pread(5,11,buffer,976775293(60801/114/47)) lseek err Invalid argument
file_pread(5,2,buffer,976777215(60801/145/16)) lseek err Invalid argument
* HPFS - NTFS 16 113 34 60801 47 46 976506880
1 P HPFS - NTFS 16 113 34 60801 47 46 976506880
NTFS at 16/113/34
mftmirr_lcn 2
NTFS at 60801/47/46
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 499 GB / 465 GiB
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 21-Jul-2015 03:15 .
5 dr-xr-xr-x 0 0 0 21-Jul-2015 03:15 ..
37 dr-xr-xr-x 0 0 0 21-Jul-2015 03:15 $RECYCLE.BIN
35 dr-xr-xr-x 0 0 0 21-Jul-2015 03:23 System Volume Information
dir_partition inode=35
Directory /System Volume Information
35 dr-xr-xr-x 0 0 0 21-Jul-2015 03:23 .
41 -r--r--r-- 0 0 131072 22-Jul-2015 07:48 001.dat
40 -r--r--r-- 0 0 131072 21-Jul-2015 19:18 002.dat
36 -r--r--r-- 0 0 20480 21-Jul-2015 19:18 tracking.log
1 * HPFS - NTFS 16 113 34 60801 47 46 976506880
SIGINT detected! TestDisk has been killed.
NTFS at 16/113/34
mftmirr_lcn 2
NTFS at 16/113/34
mftmirr_lcn 2
NTFS at 60801/47/46
mftmirr_lcn 2
Try again PhotoRec, in Options, enable the expert mode, start a recovery, use a 512 byte blocksize, use the default options otherwise. Does it recover more files this way ?
Hi cgrenier,
thanks for your hint, but unfortunately it recovers still the exact same file...
does anything else come to your mind?
