How to exclude some files to be recovered?
I've got the USB 500Gb HDD which file system were destroyed by software failure during FAT32 -> NTFS conversation. I've run photorec_win with "File Opt" checked for JPG/MPG/RIFF only. Another "File Opt"s are turned off. Many JPGs/AVIs were successfully restored until photorec_win has found some HUGE and never existant DB file (more than 90 GB of my free space). Photorec_win is trying to recover this file and stops due to lack of free space. How to exclude this DB file or files greater than some size from recovery?
Re: How to exclude some files to be recovered?
Impossible, but feature has been discussed with Christophe Grenier few weeks ago. Perhaps in next beta ?
Way to manage is : "stop" the recovery (but let open the message asking to confirm) and move the files already recovered to another hard disk. You may also supress the db file whose file is growin' and growin'. Then go on with the recovery saying "No" to the question "Are you sure you want to stop"... Just be carefull to keep the recover_dir.* and at least the first and the last.
I'm having a similar issue with an MS Office file. When it asks me to select a disk with enough free space, it'll start again at the same sector as before, so I'm not able to skip it :/
Is it at least possible to exclude certain filetypes which are include in "doc" group (ín my case a *.ppt seems to be a false positive causing the issue, but I'm actually only interested in *.xls)
If I understand correctly, it is still not possible to exclude specific files specified in the 'doc' extension?
In the second post in this tread I get the idea that it might be possible in the future?
The source, file_doc.c, looks quite advanced compared to a regular file header search but would it be possible to edit the file to turn off extensions that way. If yes, what would be the best way of doing this?
One other way to solve this is to write a script that deletes recovered files that are to big and/or files with a extension that is not of interest.
Thanks
Thanks
doc/xls/ppt/... are using the same file format. Sometimes the whole file need to be recovered before the correct extension is determined by PhotoRec.
If you really want to reject files bigger than a certain size (ie 200 MB), replace by in src/file_doc.c and recompile (./configure && make)
.max_filesize=PHOTOREC_MAX_FILE_SIZE,Code: Select all
.max_filesize=200*1024*1024,Re: How to exclude some files to be recovered?
Thank you,
I was thinking that during determination of the file maybe we can add a line to all other extensions than the one we are looking for., resulting in dropping the file rather than saving it? Would this work?
Thanks
Thanks
