I have made a USB with ALT Linux Rescue on. I am using photorec to recover files. I am having problems mounting a USB external for the recovered files.
All it seems to allow is recovery to the original disc. In the photorec manual it says: File system from external disk may be available in a /media, /mnt or /run/media sub-directory. Mount your destination drive if necessary.
I cannot find the external disk in /media, /mnt or /run/media sub-directory. I have found the drive (called LIVE) however in /dev/disk/by-label/LIVE but it puts the recovered files in the by-label directory and not onto LIVE.
How do I mount the external drive? (It is listed in photorec but will not allow recovery to the external drive)
Help would be appreciated
cannot mount external drive on ALT rescue USB
Re: cannot mount external drive on ALT rescue USB
In command line, use the "mount" command.
http://linux.die.net/man/8/mount
how do you read what is in fstab?
thanks for your help
I have the usb in the list when I first run photorec as Disk /dev/sdc usb flash drive named LIVE. Does this mean the device is mounted?
I select for the recovered files dev/disk/by-label/LIVE but when I enter this the directory / reappears
where am I going wrong?
The manual says, File system from external disk may be available in a /media, /mnt or /run/media sub-directory.
There is no disc under /media, /mnt or /run where there is no media just; mount, tmpfiles.d, udev
What is the output of the "mount" command ?
There is no mount command. There is dev media and mnt in the directory listing. (media mnt gives nothing) dev gives disk which gives by-label which lists the usb's none of which is accepted they return to the / directory.
Thanks for your help.
I am not sure I answered your post about the mount command correctly.
I'am not sure of the mount command my device is /dev/sdc what should the correct mount command be?
I did mount -t partlabel=LIVE which it accepts but still I cannot find it in the directory
I tried mount -t /dev/sdc / but it said can't find / in /etc/fstab.
I can't read fstab how do I do that?
Just type mount at the $ prompt, what is the output?
I have typed mount
which gives
udefs on /dev type devtmpfs (rw, realtime,size=8192k,nr_inodes=451961,mode=755)
/dev/sdb1 on /image type iso9660 (ro,realtime)
/dev/loop0 on /.ro type squashfs (ro,realtime)
/dev/sdb3 on / .rw type ext4 (rw,noatime,nodiratime, nobarrier, commit=30,min_batch_time=100000)
none on / type aufs (rw,rekatime,si=5609db57274d4794)
sysfs on /sys type sysfs (rw,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
runfs on /run type tmpfs (rw,relatime, size=5120k,mode=755)
devpts on /dev/pts tpe devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxdmode=000)
shmfs on /dev/shm type tmpfs (rw,relatime)
there is no mention of my external 500gbyte drive disk /dev/sdc which is listed under Select a media under photorec
what can I do? Sorry for the delay in the reply I have been ill.
which gives
I have successfully mounted a Toshiba 500GB usb with a ntfs file system.
I used the command: mount -t ntfs /dev/sdc1 /media then ran photorec
I then found the device in the media directory and it works saving the files.
I have since tried to do the same using a 64GB usb stick which has the fat32 lba file system.
I tried using the command: mount -t fat32 /dev/sdc1 /media it says there is no such file system.
Will it work with USB sticks using fat32 lba? If so what should the mount command be?
