[Solved] Impossible to mount SD card Topic is solved
nabot93
#1 Post by nabot93 »
I have a SD card that I use with my camera, when I try to plug it into my computer I have this error :
Error mounting /dev/sdb1 at /media/botella/9016-4EF8: Command-line `mount -t "vfat" -o "uhelper=udisks2,nodev,nosuid,uid=51207,gid=1000,shortname=mixed,dmask=0077,utf8=1,showexec,flush" "/dev/sdb1" "/media/botella/9016-4EF8"' exited with non-zero exit status 32: mount: /dev/sdb1: can't read superblock
So I tried to run TestDisk on it and this is what I obtain : http://pastebin.com/vPpDKg2Y
Can you help me? I really want to restore all the files that are on this card...
nabot93
Re: Impossible to mount SD card
#2 Post by nabot93 »
I understood that photorec was better to recover files, so I tried it and it worked perfectly.
I managed to recover what I needed!
Thank you for your amazing tools!
