I've checked both log files and didn't see any success using the menu Advanced that a MFT its Mirror and any data was found.
Also Quick and Deeper Search didn't find something.
That's why I'd recommend datarecovery software like PhotoRec.
PhotoRec reads and recovers underlying data ignoring the file system.
Info:
You can use the menu FileOpt and pressing s will deselect all file types, so you can select only these file types where you'd like to recover.
Multiple Primary Partitions
