bad sectors
udik
Re: bad sectors
#11 Post by udik »
I attached the log.
I received read error in search mode.
Please advise what can i do.
testdisk.zip
(2.09 KiB) Downloaded 659 times
remy
Re: bad sectors
#12 Post by remy »
It seems you also have bad sectors. Were you able to copy all what you need ? If yes, consider buying a new disk, this one is probably ot far from the end.
If no, you should also buy another disk (same size or bigger) do duplicate the first (bit to bit copy) and then work on the copy.
udik
Re: bad sectors
#13 Post by udik »
So I can't do anything now to ercover my data?
remy
Re: bad sectors
#14 Post by remy »
yes, you can : buy a new disk, make bit to bit copy, and recover from the copy... Or ask for professionnal help.
