Recovering from Windows 7 "Quick" Format
jan1215
#1 Post by jan1215 »
While attempting to to "Quick Format" a USB stick in Windows 7 64-bit, I accidentally formatted a hard drive containing years of invaluable data. I immediately recognized my error and isolated the drive so nothing else was written to the drive since.
Out of sheer desperation I Googled around for a solution and found TestDisk..I downloaded and installed version 7.0 and painstakingly followed the instructions. I've gotten as far as the instruction to reboot my computer, but regretably after doing so nothing happens and I'm unable to recover the partition. In fact I see no activity suggesting that TestDisk ran after rebooting. I'm using TestDisk 7.0 32-bit on 64-bit computer; does this make a difference? Should I be using version 7.1 instead?
Would really appreciate any help.
- James
jan1215
Re: Recovering from Windows 7 "Quick" Format
#2 Post by jan1215 »
I seem to have made some progress but I'm unsure where to go from this point. Previously I ran "Analyze" and it showed me the disk but I was unsure how to proceed after that. Now I've gone a step further and ran a Deep Search which shows the following result... what is the next step from here? Which of the two listings do I select for restore? I tried to view the files - and obviously I'm not versed in the utility - all it shows me is Recycle Bin and another file. Do I need to change the Disk Characteristics from the current "D" to "P" for recovery to work?
Thanks for all help and advice.
P.S. I've also included the latest log:
Sun Aug 9 07:14:53 2015
Compiler: GCC 4.9, Cygwin 2000.4
Compilation date: 2015-08-04T07:51:12
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=160047300608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=80026361856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=640133946880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=160047300608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=80026361856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=640133946880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=160045203456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=53687091200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=640132383744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000202043392
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - Intel Raid 0 Volume, S/N:System, FW:1.0.
Disk /dev/sdb - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - WDC WD80 0JD-60LSA0, S/N:W -DMWMAX9600276, FW:07.0
Disk /dev/sdc - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - ST364032 3AS, S/N:V90KK7BQ, FW:CC1F
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 01FALS-00E8B, S/N:W -DMWTA5V181704, FW:05.0
Disk /dev/sdd - 1000 GB / 931 GiB - WDC WD10 01FALS-00E8B
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
Info: size boot_sector 1953518988, partition 1953519616
1 P HPFS - NTFS 0 32 33 121601 25 24 1953519616
NTFS at 0/32/33
filesystem size 1953518988
mftmirr_lcn 2
HPFS - NTFS 0 32 33 121601 15 26 1953518988
file_pread(7,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(7,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(7,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(7,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(7,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(7,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(7,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(7,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(7,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(7,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(7,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(7,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(7,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(7,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 121601 25 24 1953519616
Post Deep Scan.png (36.98 KiB) Viewed 2661 times
#3 Post by cgrenier »
You can use PhotoRec to recover your files. You need enough space to store on another disk during the recovery.
Note that recovered files will not have their original names.
jan1215
#4 Post by jan1215 »
Thanks for the reply. Are you suggesting that I will not be able to recover the drive intact?
I suppose I could try PhotoRec but I'm trying to ensure that I exhaust any other possible recovery options first.
Thanks very much.
cgrenier wrote:You can use PhotoRec to recover your files. You need enough space to store on another disk during the recovery.
