Western Digital 2TB
henry21
Western Digital 2TB
#1 Post by henry21 »
Hello, first I want to thank you for the time spent helping those who do not know much about these things. I have an external hard drive of 2 TB, it was working fine until I connect to a computer running Windows XP, I got a message that did not recognize the disc. Then I plugged it into my computer with windows 7 and all information had disappeared, tells me that the disk is empty.
I has follow your tutorial step by step but i get a partition write error.
Please help me, i know the information is still there because another tool scan the disk and showed me the files but somewhat erroneous.
Please help me, i really need recover my information.
this is the info in the log:
Sat Aug 15 17:29:12 2015
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=251000193024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=314466893824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=419430400000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=419430400000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=250892779520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=59310080
filewin32_getfilesize(\\.\J:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Incorrect function.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\R:)=346865795072
Disk \\.\PhysicalDrive0 - 251 GB / 233 GiB - CHS 32422 240 63, sector size=512
Disk \\.\PhysicalDrive1 - 1500 GB / 1397 GiB - CHS 193801 240 63, sector size=512
Disk \\.\PhysicalDrive2 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive C: - 314 GB / 292 GiB - CHS 40621 240 63, sector size=512
Drive D: - 419 GB / 390 GiB - CHS 54179 240 63, sector size=512
Drive F: - 104 MB / 100 MiB - CHS 13 240 63, sector size=512
Drive G: - 250 GB / 233 GiB - CHS 32409 240 63, sector size=512
Drive H: - 59 MB / 56 MiB - CHS 14 64 32, sector size=2048
Drive K: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive R: - 346 GB / 323 GiB - CHS 44806 240 63, sector size=512
Analyse Drive K: - 2000 GB / 1862 GiB - CHS 243197 255 63
1 E extended LBA 31113 0 1 122466 254 63 1467602010
test_logical:
BAD_RS LBA=499833140 14719249
FAT16 >32M 31113 44 24 122466 55 21 1467586636
file_win32_pread(124,1,buffer,3906961407(243197/25/28)) read err: read after end of file
L FAT16 >32M 31113 44 24 122466 55 21 1467586636
add_ext_part_i386: max
add_ext_part_i386: min
5 L FAT16 >32M 31113 44 24 122466 55 21 1467586636
write!
write_all_log_i386: CHS: 31113/0/1,lba=499830345
file_win32_pwrite(124,1,buffer,499830345(31113/0/1)) write err
Partition: Write error
test_logical:
Re: Western Digital 2TB
Did you use TestDisk 64bit?
The latest version testdisk 7.1WIP 32bit is recommended.
In TestDisk disk selection you should select Disk / Dev .. instead of a Drive.
Please repeat your diagnose and copy and paste the content of your testdisk.log into your next post.
henry21
#3 Post by henry21 »
Yes i did (64bit)
Ok, im doing right now with 7.1 32bit
ok, its done
ok, I will, (runinng diagnostic just now) i will paste it tomorrow
#4 Post by Fiona »
Your current partition structure on your dirve contains an extended partition only.
That's why running testdisk / Advanced on an extended partition didn't help as much.
Selecting Disk / dev displays at Analyse your current partition structure (partition table) correctly.
