Hi guys,
Could anybody help me?...
I have a chance to find my files .ino (Arduino Files simple notepad editable text files with .ino extention)
Unfortunately my photorec.sig seems not working properly
Or could you please send me a hint whats wrong with my photorec.sig file wich contains:
ino 0 "Arduino File"
Sample Arduino files:
I uploaded samples to http://100di.ru/samples.zip
Thank you in advance!
.ino files (Arduino robot)
Re: .ino files (Arduino robot)
You can create a photorec.sig file with
Or search in the various text files recovered by PhotoRec
ino 0 "/* Robot"
ino 0 "/* Runaway Robot"
Thank you Christophe for the reply.
Unfortunately smth wrong with mine sig file. Is it wrong? Would you please look
Christophe, my robot has files with different names but all files with .ino extention.
No files found with suggested .sig file..
There is smth need to change.
Any ideas?
Any ideas?
No luck so far...
Could anybody explain how to create a simple .sig to find all the files with .ino extention?..
The signature is about the file content, not the file extension.
If all your .ino files begin by the same content, you can create a signature.
If all your .ino files contains some specific word, you can search for this word in all the recovered files.
