Should i go ahead and write?
Protino
#1 Post by Protino »
Yesterday I had problems with windows 10, i was stuck on automatic repair loop, but everything was fine with the disk.
I was playing around with diskpart like a fool this morning - reassigning drive letters.
I have 4 partitions
C: System reserved
E: System (WHere windows folder resides)
D:Multimedia (Logical drive)
W:Workspace(Logical Drive)
I seleceted volome c: and typed clean (Thinking it will clean some configuration data)
Then BAAM! everything is gone.
So i googled and ended up on cgsecurity.org. Now I've using a live cd of ubuntu i followed steps explained by the site.
When i select analyse and later do quicksearch
i get this :
I there any problem if i write now?
Re: Should i go ahead and write?
Set the second partition as *(bootable) instead of the first.
