Help needed with recovering data from RAW Partition
harizsofia
#1 Post by harizsofia »
Hello, i am running Windows 7 64 Bit. My laptop freezed and when I restarted it, one of the partitions on my harddisk had changed from NTFS to RAW. Upon running Testdisk analysis, this is what it showed:TestDisk 7.0, Data Recovery Utility, April 2015
Drive D: - 295 GB / 274 GiB - CHS 35889 255 63
1 * Sys=4F 120527 49 53 234813 237 34 1836016416
Bad relative sector.
2 * Sys=73 119380 132 62 153270 41 37 544437093
3 * Sys=2B 113201 29 24 147074 114 59 544175136
4 * SpeedStor 177063 118 26 177066 225 63 54974
>[Quick Search] [ Backup ]
Try to locate partition
I then did a quicksearch, i received the following message:TestDisk 7.0, Data Recovery Utility, April 2015
The harddisk (295 GB / 274 GiB) seems too small! (< 1465 GB / 1364 GiB)
> FAT12 132009 145 40 178144 139 43 741158401
[ Continue ]
379 GB / 353 GiB
Then advanced search resulted in this:
[ Continue ]
379 GB / 353 GiB
I am not sure how to proceed now because it says the partition cant be recovered. Is there any way i can recover my harddisk and data?
Thanks in advance for any help u can provide..
Re: Help needed with recovering data from RAW Partition
Under disk selection you should select Disk instead of a drive.
Please use the latest version of TestDisk 7.1 WIP 32bit.
Can you repeat your diagnose and copy and paste the content of your testdisk.log again?
Most important would be Analyse and your current partition structure (partition table).
If all partition in your partition table are correct, you can have a try to run a boot sector diagnose.
Info will follow.
harizsofia
#3 Post by harizsofia »
Hi, thanks for responding. I downloaded Testdisk 7.1 WIP and did as you mentioned. The analyse step gave me this output:
TestDisk 7.1-WIP, Data Recovery Utility, September 2015
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63
1 P Dell Utility 0 1 1 4 254 63 80262
2 * HPFS - NTFS 5 25 21 2644 189 41 42405888
3 P HPFS - NTFS 2644 189 42 17404 120 62 237115074
4 E extended LBA 17404 120 63 91200 254 63 1185541183
5 L HPFS - NTFS 17404 121 63 53293 254 54 576565156
X extended 53294 0 1 91200 254 63 608975955
6 L HPFS - NTFS 53294 1 1 91200 254 63 608975892
Then I performed a quicksearch and this is what resulted:
>* FAT16 >32M 0 1 1 4 254 63 80262 [DellUtility]
P HPFS - NTFS 5 25 21 2644 189 41 42405888
L HPFS - NTFS 17404 121 63 53293 254 51 576565153
Enter: to continue
Am not sure how to proceed from here though.. Appreciate the help!
#4 Post by Fiona »
It looks better now.
Altough you left out some parts of the testdisk.log.
But I found something.
The length of a partition in your partition table and found after quick search differ.
You can see it here:
The sector value in your partition table is 54.
After Quick Search the sector value is 51.
It can cause such behavior.
Can you select this partition and press p to have a try to list your files?
You can get back by pressing q for Quit.
As far as I've seen you have a Dell Computer.
There is something to watch writing it to your partition table.
It's your Dell Utility partition.
Info will follow.
Please let me know, is this your affected partition?
harizsofia
#5 Post by harizsofia »
Yes I am able to select the partition that you mentioned and was able to list the files. And yes, I do have a Dell computer.
The partition that you mentioned is the one that I am having trouble with.
Looking forward to hearing from you.
#6 Post by Fiona »
After Quick Search, your Dell Utility labeled FAT16-partition must be selected.
Press t for Type (partition type) on your keyboard.
Press enter to proceed.
At the bottom of the display you can watch your current partition type.
Easily type de for Dell Utility.
Press Enter to close the menu Type.
This procedure changes your FAT16-partition back to your Dell Utility-Partition and will be not visible under Windows.
It's a manufacturer setting and it's intended that users can't change anything.
Now you have to set the right partition as active and bootable.
It's this partition:
Please select it and use the right or left arrow key on your keyboard to set it to Star* instead of P for primary only.
You can watch it at the left.
Your display should look like this:
Press enter (your extended partition appears here automatically), check the menu Write, press enter again and confirm with yes.
Close TestDisk using Quit and restart your PC.
harizsofia
#7 Post by harizsofia »
I completed all the steps until the part where I had to change the Star part using the arrow keys. I think I have done it the way you mentioned, but I would just like to check with you if this is correct as i show below. I am not really sure because in your example there is a 1 before the P for the Dell Utility, but using the arrows on my computer doesn't give me the 1?
Also, after restarting, will my partition be back to normal? Should I backup my data before proceeding with the next step?
This is what I have... can you confirm if this is correct and I can proceed?
P Dell Utility 0 1 1 4 254 63 80262 [DellUtility]
Enter: to continue
#8 Post by Fiona »
Yes, everything looks correct.
The 1 was copied out of your partition table here:
You should write your partition structure now as it is.
harizsofia
#9 Post by harizsofia »
Ok,have done as you asked and restarted my laptop. However, the partition that I am having problems with is still RAW instead of NTFS, as you can see in the attachment.
Also if I run TestDisk again, the partitions look like this.. is this correct?
Enter: to continue
#10 Post by Fiona »
I didn't have the full log file.
That's why it was for me difficult to judge, do you have any problem with your file system or boot sector?
You can run testdisk again.
Don't confirm at analyse but advanced.
Select your affected partition and confirm at boot.
Please upload another snapshot.
Info will follow.
