lacie raid 1
lacie raid 1
i bought a Lacie raid1 and the box failed, easy buy another lacie raid1 and plug in the old drives, sorry lacie is not backwards compatable "this is a feature not a bug".
lacie support recommends installing one drive in a ubuntu 12.04 linux computer and using testdisk to recover data.
when i started i could see the linux array in home folder but could not read it. after a week of playing with testdisk, reading almost ever post in this forum, searching the internet and youtube i can no longer see the linux array in home folder but testdisk still sees it fine.
i still have my second raid 1 drive intact so im safe to play with the first one.
what do i have to do to made the raid 1 disk readable?
thank you for your time
peter
peter
Re: lacie raid 1
Please give feedback :
and if your disk is /dev/sdb, for each partition (/dev/sdb1, /dev/sdb2...) :
and also :
and last, but not least feedback (copy/paste) about what you can see with testdisk (Analyse/Quicksearch/Deepercearch) in different stages.
sudo sfdisk -luSCode: Select all
sudo mdadm --examine /dev/sdbXCode: Select all
cat /proc/mdstatRe: lacie raid 1
ok here is the log from testdisk the 3 commands do not seem to work. i did the search and the deep serach i hope this helps? thank you for your time
Mon May 21 19:05:53 2012
OS: Linux, kernel 3.2.0-23-generic-pae (#36-Ubuntu SMP Tue Apr 10 22:19:09 UTC 2012) i686
Compiler: GCC 4.6
Compilation date: 2012-02-05T07:16:54
ext2fs lib: 1.42, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size 156312576 sectors
/dev/sda: user_max 156312576 sectors
/dev/sda: native_max 156312576 sectors
/dev/sda: dco 156312576 sectors
/dev/sdb: size 976773168 sectors
/dev/sdb: user_max 976773168 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sdb: dco 976773168 sectors
Disk /dev/sda - 80 GB / 74 GiB - CHS 9730 255 63, sector size=512 - WDC WD800JD-08MSA1, S/N:WD-WMAM9WJ42031, FW:10.01E01
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500620AS, S/N:9QM5Y5KR, FW:LC11
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST310005 20AS
Disk /dev/sdb - 500 GB / 465 GiB - ST3500620AS
Raid magic value at 40/1/1
Raid apparent size: 1349248 sectors
Raid chunk size: 0 bytes
check_MD 0.90
md2 md 0.90.0 Raid 1: devices 0(8,9)* 1(8,25)
1 * Linux RAID 40 1 1 123 254 63 1349397 [md2]
Ask the user for vista mode
search_vista_part: 0
recover_EXT2: s_block_group_nr=0/0, s_mnt_count=1/34, s_blocks_per_group=8192, s_inodes_per_group=1984
recover_EXT2: s_blocks_count 7936
recover_EXT2: part_size 15872
Linux 17 1 1 17 252 59 15872
EXT3 Sparse superblock, 8126 KB / 7936 KiB
Raid magic value at 17/252/60
Raid apparent size: 15872 sectors
md0 md 0.90.0 Raid 1: devices 0(8,7)* 1(8,23)
Linux RAID 17 1 1 17 254 61 16000 [md0]
md 0.90.0 Raid 1: devices 0(8,7)* 1(8,23), 8192 KB / 8000 KiB
recover_EXT2: s_block_group_nr=0/21, s_mnt_count=3/34, s_blocks_per_group=8192, s_inodes_per_group=2008
recover_EXT2: s_blocks_count 176576
recover_EXT2: part_size 353152
Linux 18 1 1 39 251 37 353152
EXT3 Sparse superblock, 180 MB / 172 MiB
Raid magic value at 39/251/38
Raid apparent size: 353152 sectors
md1 md 0.90.0 Raid 1: devices 0(8,8)* 1(8,24)
Linux RAID 18 1 1 39 253 39 353280 [md1]
md 0.90.0 Raid 1: devices 0(8,8)* 1(8,24), 180 MB / 172 MiB
recover_EXT2: s_block_group_nr=0/5, s_mnt_count=10/35, s_blocks_per_group=32768, s_inodes_per_group=14080
recover_EXT2: s_blocks_count 168656
recover_EXT2: part_size 1349248
Linux 40 1 1 123 252 40 1349248
EXT3 Sparse superblock, 690 MB / 658 MiB
Raid magic value at 123/252/41
Linux RAID 40 1 1 123 254 42 1349376 [md2]
md 0.90.0 Raid 1: devices 0(8,9)* 1(8,25), 690 MB / 658 MiB
XFS Marker at 125/0/1
recover_xfs
Linux 125 0 1 121476 250 51 1949519616
XFS 6.2+ - bitmap version, 998 GB / 929 GiB
This partition ends after the disk limits. (start=2008125, size=1949519616, end=1951527740, disk end=976773168)
Raid magic value at 60800/252/58
Raid apparent size: 0 sectors
Raid chunk size: 65536 bytes
md4 md 0.90.0 Raid 4294967295: devices 0(8,2)* 1(8,18)
Linux RAID 60800 252 58 60800 254 59 128 [md4]
md 0.90.0 Raid 4294967295: devices 0(8,2)* 1(8,18), 65 KB / 64 KiB
The harddisk (500 GB / 465 GiB) seems too small! (< 999 GB / 930 GiB)
get_geometry_from_list_part_aux head=255 nbr=8
Linux 17 1 1 17 254 63 16002
EXT3 Sparse superblock, 8193 KB / 8001 KiB
Linux RAID 17 1 1 17 254 63 16002 [md0]
md 0.90.0 Raid 1: devices 0(8,7)* 1(8,23), 8193 KB / 8001 KiB
Linux 18 1 1 39 254 63 353367
Linux RAID 18 1 1 39 254 63 353367 [md1]
Linux 40 1 1 123 254 63 1349397
L Linux RAID 60800 252 58 60800 254 63 132 [md4]
md 0.90.0 Raid 4294967295: devices 0(8,2)* 1(8,18), 67 KB / 66 KiB
1 E extended LBA 60800 252 1 60800 254 63 189
5 L Linux RAID 60800 252 58 60800 254 63 132 [md4]
block_group_nr 3
recover_EXT2: "e2fsck -b 24577 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=3/21, s_mnt_count=0/34, s_blocks_per_group=8192, s_inodes_per_group=2008
EXT3 Sparse superblock Backup superblock, 180 MB / 172 MiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/5, s_mnt_count=9/35, s_blocks_per_group=32768, s_inodes_per_group=14080
EXT3 Sparse superblock Backup superblock, 690 MB / 658 MiB
recover_xfs
write_all_log_i386: CHS: 60800/252/1,lba=976767876
Compiler: GCC 4.6
check_MD 0.90
recover_xfs
block_group_nr 3
block_group_nr 3
recover_xfs
Re: lacie raid 1
There's an XFS partition detected, whose size is not far from 1TB. Your raid may be a Raid0 or a linear. Are you sure for raid 1 ?
Re: lacie raid 1
the lacie ships as a raid 0 i switched it to a raid 1 there is a rotory switch with an arrow on it, i changed it to raid 1 and i just checked the setting and it was pointing at raid 1 or safe 100 mode.
reading the manual if you switch modes it will delete the prevous settings, so that may be why the deleted raid 0 shows up.
here is the manual and page 54 has the setting
http://www.lacie.com/download/manual/2bigNetwork_en.pdf
Re: lacie raid 1
Please more precision : what about the second lacie box : was it in raid 1 also ?
Where are you passing the commande I gave ?
Re: lacie raid 1
i onlly have one box i thought i could buy another box but they are not backward compatable.
i tried the 3 commands and and i came up with error messages
Re: lacie raid 1
peter
peter
Re: lacie raid 1
sorry when i tried mdadm it did not work so with some searching i realized i had to install mdadm so here is what i got
peter@lonovo:~$ sudo mdadm --examine /dev/sdb1
/dev/sdb1:
Magic : a92b4efc
Version : 0.90.00
UUID : 85797f43:653296b6:a4ca4023:b3f44802
Creation Time : Fri Dec 31 16:00:19 1999
Raid Level : raid1
Used Dev Size : 674624 (658.92 MiB 690.81 MB)
Array Size : 674624 (658.92 MiB 690.81 MB)
Raid Devices : 2
Total Devices : 2
Preferred Minor : 2
Update Time : Tue Jun 24 01:38:14 2003
State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Checksum : 655251b7 - correct
Events : 10904458
Number Major Minor RaidDevice State
this 0 8 9 0 active sync
0 0 8 9 0 active sync
1 1 8 25 1 active sync
/dev/sdb1:
Magic : a92b4efc
Version : 0.90.00
Raid Level : raid1
Raid Devices : 2
Total Devices : 2
Preferred Minor : 2
State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Events : 10904458
Re: lacie raid 1
OK, and what about the two other commands (sfdisk -luS and cat /proc/mdstat) ?
After that, disconnect your disk, plug the other one, and give the same 3 commands.
