lacie raid 1
Re: lacie raid 1
peter@lonovo:~$ cat /proc/mdstat
Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
unused devices: <none>
peter@lonovo:~$ sudo sfdisk -1uS
[sudo] password for peter:
Usage:
sfdisk [options] <device> [...]
Options:
-s, --show-size list size of a partition
-c, --id change or print partition Id
--change-id change Id
--print-id print Id
-l, --list list partitions of each device
-d, --dump idem, but in a format suitable for later input
-i, --increment number cylinders etc. from 1 instead of from 0
-u, --unit <letter> units to be used; <letter> can be one of
S (sectors), C (cylinders), B (blocks), or M (MB)
-1, --one-only reserved option that does nothing currently
-T, --list-types list the known partition types
-D, --DOS for DOS-compatibility: waste a little space
-E, --DOS-extended DOS extended partition compatibility
-R, --re-read make the kernel reread the partition table
-N <number> change only the partition with this <number>
-n do not actually write to disk
-O <file> save the sectors that will be overwritten to <file>
-I <file> restore sectors from <file>
-V, --verify check that the listed partitions are reasonable
-v, --version display version information and exit
-h, --help display this help text and exit
Dangerous options:
-f, --force disable all consistency checking
--no-reread do not check whether the partition is in use
-q, --quiet suppress warning messages
-L, --Linux do not complain about things irrelevant for Linux
-g, --show-geometry print the kernel's idea of the geometry
-G, --show-pt-geometry print geometry guessed from the partition table
-A, --activate[=<device>] activate bootable flag
-U, --unhide[=<dev>] set partition unhidden
-x, --show-extended also list extended partitions in the output,
or expect descriptors for them in the input
--leave-last do not allocate the last cylinder
--IBM same as --leave-last
--in-order partitions are in order
--not-in-order partitions are not in order
--inside-outer all logicals inside outermost extended
--not-inside-outer not all logicals inside outermost extended
--nested every partition is disjoint from all others
--chained like nested, but extended partitions may lie outside
--onesector partitions are mutually disjoint
Override the detected geometry using:
-C, --cylinders <number> set the number of cylinders to use
-H, --heads <number> set the number of heads to use
-S, --sectors <number> set the number of sectors to use
peter@lonovo:~$
Usage:
Options:
--print-id print Id
Dangerous options:
peter@lonovo:~$
Re: lacie raid 1
Usage:
Options:
--print-id print Id
Dangerous options:
peter@lonovo:~$ cat /proc/stat
cpu 2035 383 999 16516 2563 0 15 0 0 0
cpu0 2035 383 999 16516 2563 0 15 0 0 0
intr 39620 47 118 0 0 0 0 3 1 1 2 0 0 0 0 0 0 881 568 7988 2 0 0 16098 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 161 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
ctxt 126479
btime 1337920023
processes 2189
procs_running 1
procs_blocked 0
softirq 49920 0 10384 39 244 16190 0 110 0 8 22945
peter@lonovo:~$
Usage:
Options:
--print-id print Id
Dangerous options:
ctxt 126479
btime 1337920023
processes 2189
procs_running 1
procs_blocked 0
peter@lonovo:~$
Re: lacie raid 1
raid 1 disk 2
Thu May 24 17:42:30 2012
OS: Linux, kernel 3.2.0-23-generic-pae (#36-Ubuntu SMP Tue Apr 10 22:19:09 UTC 2012) i686
Compiler: GCC 4.6
Compilation date: 2012-02-05T07:16:54
ext2fs lib: 1.42, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size 156312576 sectors
/dev/sda: user_max 156312576 sectors
/dev/sda: native_max 156312576 sectors
/dev/sda: dco 156312576 sectors
/dev/sdb: size 976773168 sectors
/dev/sdb: user_max 976773168 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sdb: dco 976773168 sectors
Warning: can't get size for Disk /dev/md - 0 B - CHS 1 1 1 (RO), sector size=512
Disk /dev/sda - 80 GB / 74 GiB - CHS 9730 255 63, sector size=512 - WDC WD800JD-08MSA1, S/N:WD-WMAM9WJ42031, FW:10.01E01
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500620AS, S/N:9QM5Y4GD, FW:LC11
Disk /dev/sdb - 500 GB / 465 GiB - ST3500620AS
XFS Marker at 125/0/1
get_geometry_from_list_part_aux head=255 nbr=24
get_geometry_from_list_part_aux head=8 nbr=6
get_geometry_from_list_part_aux head=16 nbr=4
get_geometry_from_list_part_aux head=240 nbr=3
1 E extended 0 1 1 124 254 63 2008062
2 P Linux 125 0 1 60800 254 63 974759940
5 L Linux Swap 0 2 1 15 254 63 256914
X extended 16 0 1 16 254 63 16065
6 L Linux 16 1 1 16 254 63 16002
X extended 17 0 1 17 254 63 16065
7 L Linux 17 1 1 17 254 63 16002
X extended 18 0 1 39 254 63 353430
8 L Linux 18 1 1 39 254 63 353367
X extended 40 0 1 123 254 63 1349460
9 L Linux 40 1 1 123 254 63 1349397
X extended 124 0 1 124 254 63 16065
10 L Linux 124 1 1 124 254 63 16002
Ask the user for vista mode
search_vista_part: 0
Linux Swap 0 2 1 15 252 27 256752
SWAP2 version 1, 131 MB / 125 MiB
Raid magic value at 15/252/44
Raid apparent size: 256768 sectors
Raid chunk size: 0 bytes
md126 md 0.90.0 Raid 4293967296: devices 0(8,21)*
Linux RAID 0 2 1 15 254 45 256896 [md126]
md 0.90.0 Raid 4293967296: devices 0(8,21)*, 131 MB / 125 MiB
recover_EXT2: s_block_group_nr=0/0, s_mnt_count=1/34, s_blocks_per_group=8192, s_inodes_per_group=1984
recover_EXT2: s_blocks_count 7936
recover_EXT2: part_size 15872
Linux 17 1 1 17 252 59 15872
EXT3 Sparse superblock, 8126 KB / 7936 KiB
Raid magic value at 17/252/60
Raid apparent size: 15872 sectors
md124 md 0.90.0 Raid 4293967296: devices 0(8,23)*
Linux RAID 17 1 1 17 254 61 16000 [md124]
md 0.90.0 Raid 4293967296: devices 0(8,23)*, 8192 KB / 8000 KiB
recover_EXT2: s_block_group_nr=0/21, s_mnt_count=3/34, s_blocks_per_group=8192, s_inodes_per_group=2008
recover_EXT2: s_blocks_count 176576
recover_EXT2: part_size 353152
Linux 18 1 1 39 251 37 353152
EXT3 Sparse superblock, 180 MB / 172 MiB
Raid magic value at 39/251/38
Raid apparent size: 353152 sectors
md125 md 0.90.0 Raid 4293967296: devices 0(8,24)*
Linux RAID 18 1 1 39 253 39 353280 [md125]
md 0.90.0 Raid 4293967296: devices 0(8,24)*, 180 MB / 172 MiB
recover_EXT2: s_block_group_nr=0/5, s_mnt_count=10/35, s_blocks_per_group=32768, s_inodes_per_group=14080
recover_EXT2: s_blocks_count 168656
recover_EXT2: part_size 1349248
Linux 40 1 1 123 252 40 1349248
EXT3 Sparse superblock Recover, 690 MB / 658 MiB
Raid magic value at 123/252/41
Raid apparent size: 1349248 sectors
md2 md 0.90.0 Raid 4293967296: devices 0(8,25)*
Linux RAID 40 1 1 123 254 42 1349376 [md2]
md 0.90.0 Raid 4293967296: devices 0(8,25)*, 690 MB / 658 MiB
recover_xfs
Linux 125 0 1 121476 250 51 1949519616
XFS 6.2+ - bitmap version, 998 GB / 929 GiB
This partition ends after the disk limits. (start=2008125, size=1949519616, end=1951527740, disk end=976773168)
Raid magic value at 60800/252/58
Raid apparent size: 974759808 sectors
md127 md 0.90.0 Raid 4293967296: devices 0(8,18)*
Linux RAID 125 0 1 60800 254 59 974759936 [md127]
md 0.90.0 Raid 4293967296: devices 0(8,18)*, 499 GB / 464 GiB
The harddisk (500 GB / 465 GiB) seems too small! (< 999 GB / 930 GiB)
get_geometry_from_list_part_aux head=255 nbr=10
Linux RAID 0 2 1 15 254 63 256914 [md126]
EXT3 Sparse superblock, 8193 KB / 8001 KiB
Linux RAID 17 1 1 17 254 63 16002 [md124]
md 0.90.0 Raid 4293967296: devices 0(8,23)*, 8193 KB / 8001 KiB
Linux RAID 18 1 1 39 254 63 353367 [md125]
Linux RAID 40 1 1 123 254 63 1349397 [md2]
* Linux RAID 125 0 1 60800 254 63 974759940 [md127]
1 * Linux RAID 125 0 1 60800 254 63 974759940 [md127]
block_group_nr 3
recover_EXT2: "e2fsck -b 24577 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=3/21, s_mnt_count=0/34, s_blocks_per_group=8192, s_inodes_per_group=2008
EXT3 Sparse superblock Backup superblock, 180 MB / 172 MiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/5, s_mnt_count=9/35, s_blocks_per_group=32768, s_inodes_per_group=14080
EXT3 Sparse superblock Backup superblock, 690 MB / 658 MiB
recover_xfs
Compiler: GCC 4.6
recover_xfs
block_group_nr 3
block_group_nr 3
recover_xfs
Re: lacie raid 1
raid 1 disk 2
peter@lonovo:~$ sudo mdadm --examine /dev/sdb1
/dev/sdb1:
MBR Magic : aa55
Partition[0] : 256914 sectors at 63 (type 82)
Partition[1] : 16065 sectors at 256977 (type 05)
peter@lonovo:~$
Usage:
Options:
--print-id print Id
Dangerous options:
cpu 81662 636 47255 946538 242795 3 5536 0 0 0
cpu0 81662 636 47255 946538 242795 3 5536 0 0 0
intr 3125439 91 352 0 0 0 0 3 1 1 2 0 0 0 0 0 0 879 10062 516868 2 0 0 1685650 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2155 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
ctxt 8447099
btime 1337906261
processes 2439
procs_running 3
procs_blocked 0
softirq 3161630 0 531816 2670 2333 1685805 0 323 0 1120 937563
peter@lonovo:~$
/dev/sdb1:
MBR Magic : aa55
peter@lonovo:~$
Usage:
Options:
--print-id print Id
Dangerous options:
ctxt 8447099
btime 1337906261
processes 2439
procs_running 3
procs_blocked 0
peter@lonovo:~$
Re: lacie raid 1
sudo sfdisk -luS
cat /proc/mdstat
Re: lacie raid 1
i installed both drives in the computer so sdb and sdc are the raid drives, i notice there is a difference has sdb failed and sdc the good drive since there is more on it? i hope this helps?
peter@lonovo:~$ sudo sfdisk -luS
Disk /dev/sda: 9730 cylinders, 255 heads, 63 sectors/track
Warning: extended partition does not start at a cylinder boundary.
DOS and Linux will interpret the contents differently.
Units = sectors of 512 bytes, counting from 0
Device Boot Start End #sectors Id System
/dev/sda1 2048 10065919 10063872 27 Hidden NTFS WinRE
/dev/sda2 * 10065920 140980856 130914937 7 HPFS/NTFS/exFAT
/dev/sda3 140982270 156311551 15329282 5 Extended
/dev/sda4 0 - 0 0 Empty
/dev/sda5 140982272 155396095 14413824 83 Linux
/dev/sda6 155398144 156311551 913408 82 Linux swap / Solaris
Disk /dev/sdb: 60801 cylinders, 255 heads, 63 sectors/track
/dev/sdb1 * 642663 1992059 1349397 fd Linux raid autodetect
/dev/sdb2 0 - 0 0 Empty
/dev/sdb3 0 - 0 0 Empty
/dev/sdb4 0 - 0 0 Empty
Disk /dev/sdc: 60801 cylinders, 255 heads, 63 sectors/track
/dev/sdc1 63 2008124 2008062 5 Extended
/dev/sdc2 2008125 976768064 974759940 83 Linux
/dev/sdc3 0 - 0 0 Empty
/dev/sdc4 0 - 0 0 Empty
/dev/sdc5 126 257039 256914 82 Linux swap / Solaris
/dev/sdc6 257103 273104 16002 83 Linux
/dev/sdc7 273168 289169 16002 83 Linux
/dev/sdc8 289233 642599 353367 83 Linux
/dev/sdc9 642663 1992059 1349397 83 Linux
/dev/sdc10 1992123 2008124 16002 83 Linux
peter@lonovo:~$
Re: lacie raid 1
i also tried this
peter@lonovo:~$ sudo mdadm --assemble -scan
mdadm: WARNING /dev/sdc9 and /dev/sdc8 appear to have very similar superblocks.
If they are really different, please --zero the superblock on one
If they are the same or overlap, please remove one from the
DEVICE list in mdadm.conf.
mdadm: No arrays found in config file or automatically
Re: lacie raid 1
As far as it should have been a raid1, either you've made deep transformations, or a drive is really corrupted. sdc and sdb must be equal.
I don't know why you have so much partition on sdc.
Please give feedback :
sudo blkid
Re: lacie raid 1
The 2big Network is running a Linux operating system with XFS file system
Re: lacie raid 1
I know that. mdadm based. What's the return of blkid ?
