Help after Deeper Search
BAYRKL
#1 Post by BAYRKL »
Hi All,
I followed the "TestDisk Step By Step" to fix my 1TB external hard drive that suddenly became RAW, and (I do not know how to say) there is no partitions (I did not divide it to partitions) I kept it as one drive.
However, after "Quick Search" I didn't find my partition "A partition is still missing: Deeper Search", SO, I pressed Deeper Search, then, after Deep Search finished, I surprised that still there is no partition ( as shown in the picture)
Please, can you guide me
After Deeper Search
After Deeper Search
Re: Help after Deeper Search
Run TestDisk, if you choose H:, select partition type None, Advanced, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit
JayZon
#3 Post by JayZon »
I think i have the same problem..ive done what you said..but after the selecting the advanced all I see in the options are TYPE,CREATE IMAGE..what will I do nxt??pls help
