I have recovered my files and the files were in the directories.
There is a problem!
The extension of the files was .XML and .SQLITE - the size of the files was OK.
What happened and how to fix?
Thanks!
Jure
Problems recovering files from Nokia E7
Re: Problems recovering files from Nokia E7
What do you mean ? What is your problem ?
