Testdisk seems to work but drive still says "unformatted"
SteveBondy
#1 Post by SteveBondy »
Anyway, I am trying to recover an external drive and have a strange problem. Testdisk finds the partition and I can list files, and copy individual files to my system. Testdisk appears to write the partition table successfully, but if I disconnect the drive and reconnect it, Windows still says it's unformatted.
Here's the log:
Sorry if this post gets duplicated - I posted once but it just disappeared, so I'm re-posting.
Anyway, I am trying to recover a drive and have a strange problem. Testdisk finds the partition and I can list files, and copy individual files to my system. Testdisk appears to write the partition table successfully
Fri Oct  9 17:14:24 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=60011642880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=60011642880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=104857600000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=790384082944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=59995160064
Disk /dev/sdb - 60 GB / 55 GiB - CHS 7296 255 63, sector size=512
Drive C: - 104 GB / 97 GiB - CHS 12748 255 63, sector size=512
Drive D: - 790 GB / 736 GiB - CHS 96092 255 63, sector size=512
Drive F: - 59 GB / 55 GiB - CHS 7293 255 63, sector size=512
Analyse Disk /dev/sdb - 60 GB / 55 GiB - CHS 7296 255 63
FAT32 at 0/1/1
Info: size boot_sector 117178047, partition 117178047
FAT1 : 32-14334
FAT2 : 14335-28637
start_rootdir : 28638 root cluster : 2
Data : 28638-117178013
sectors : 117178047
cluster_size : 64
no_of_cluster : 1830459 (2 - 1830460)
fat_length 14303 calculated 14301
 1 * FAT32 LBA                0   1  1  7293 254 63  117178047 [TRAVELODGE]
FAT32 at 0/1/1
FAT1 : 32-14334
FAT2 : 14335-28637
sectors : 117178047
cluster_size : 64
FAT32 at 0/1/1
     FAT32, blocksize=32768, 59 GB / 55 GiB
file_pread(5,2,buffer,117211136(7296/14/15)) lseek err Invalid argument
file_pread(5,1,buffer,117211136(7296/14/15)) lseek err Invalid argument
file_pread(5,1,buffer,117210240(7296/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,117210241(7296/0/2)) lseek err Invalid argument
file_pread(5,3,buffer,117210255(7296/0/16)) lseek err Invalid argument
file_pread(5,3,buffer,117210302(7296/0/63)) lseek err Invalid argument
file_pread(5,8,buffer,117210318(7296/1/16)) lseek err Invalid argument
file_pread(5,11,buffer,117210365(7296/1/63)) lseek err Invalid argument
file_pread(5,2,buffer,117212287(7296/32/32)) lseek err Invalid argument
file_pread(5,1,buffer,117210258(7296/0/19)) lseek err Invalid argument
file_pread(5,1,buffer,117210305(7296/1/3)) lseek err Invalid argument
file_pread(5,1,buffer,117210326(7296/1/24)) lseek err Invalid argument
file_pread(5,1,buffer,117210376(7296/2/11)) lseek err Invalid argument
file_pread(5,1,buffer,117212289(7296/32/34)) lseek err Invalid argument
dir_partition inode=0
FAT: cluster=2(0x2), pos=28701
FAT: cluster=38277(0x9585), pos=2478301
 1376327 drwxr-xr-x     0      0         0 27-Jan-2015 07:53 Diabetes
  587275 drwxr-xr-x     0      0         0 24-Sep-2015 23:45 FOUND.000
X    180 drwxr-xr-x     0      0     32768 19-Sep-2015 09:00 _SIF85C7.TMP
X    180 drwxr-xr-x     0      0     32768 19-Sep-2015 08:36 214042ea-1dbe
X    161 -rwxr-xr-x     0      0     33280 26-Jul-2014 21:17 2014-07-11 to
 1311187 drwxr-xr-x     0      0         0  9-Sep-2014 07:55 Scanned
  590660 drwxr-xr-x     0      0         0 29-Oct-2014 08:48 Paul
 1379618 -rwxr-xr-x     0      0    319720 23-Feb-2015 08:30 Brochure - Camp Discovery 2015.pdf
    2064 drwxr-xr-x     0      0         0 17-Apr-2007 14:57 System Volume Information
 1376262 drwxr-xr-x     0      0         0 23-Feb-2015 10:44 Recycled
X    621 -rwxr-xr-x     0      0    137454 20-Oct-2014 08:33 _014-1~2.JPE
<snip>
X  21670 drwxr-xr-x     0      0     32768  5-Jun-2013 08:04 MSI2407b.tmp
<snip>
<snip>
write!
Any help or advice would be greatly appreciated.
Thanks,
Steve
Re: Testdisk seems to work but drive still says "unformatted
Run "cmd" (right click run as administrator) and type "chkdsk /f d:" (replace d: by the correct drive letter)
SteveBondy
#3 Post by SteveBondy »
Ah. Thanks for that. Chkdsk wouldn't recognize it before so I hadn't thought to go back and try again. But that explains what's going on:
C:\>chkdsk /f f:
The type of the file system is FAT32.
An error occurred while reading the file allocation table (FAT 1).
An error occurred while reading the file allocation table (FAT 2).
There are no readable file allocation tables (FAT).
C:\>
I guess I'll just manually copy the files. I don't think there's a way around this one is there?
Steve
