Hi all.
Couple of days ago I unfortunatelly started wiping my disk and after that my computer was unable to find bootable device.
I was trying to fix mbr but without satisfying results. Fortunatly some data on one partition (MY D PARTITION) was there, but partition with windows (MY C PARTITION) wasn't.
I used a program to recover partitions with the result of having one partition containing EFI folder but the rest of the disk became unallocated (diskmngt with the possition of appearance: 806 GB - unallocated, 300 MB - EFI, 124 GB unallocated).
So I used testdisk (log file attached) in deepsearch mode and I have:
HPFS - NTFS 0 1 1 22323 254 63 358634997
NTFS found using backup sector, blocksize=4096, 183 GB / 171 GiB
HPFS - NTFS 22323 254 63 44647 253 62 358634997
NTFS, blocksize=4096, 183 GB / 171 GiB
HPFS - NTFS 22324 0 1 121600 254 63 1594885005 [Nowy]
NTFS, blocksize=4096, 816 GB / 760 GiB
HPFS - NTFS 22324 0 5 121600 254 63 1594885001 [Nowy]
NTFS found using backup sector, blocksize=4096, 816 GB / 760 GiB
HFS 63834 94 5 66088 96 56 36210688
HFS blocksize=289669120, 18 GB / 17 GiB
FAT32 LBA 105330 194 61 105369 2 21 614400 [SYSTEM]
FAT32, blocksize=4096, 314 MB / 300 MiB
Only the partition labeled [Nowy] (the first one) can be listed with files (which is MY D PARTITION) and the FAT32 LBA partition can be listed with EFI folder (containing other folders inside).
The rest shows message: "Can't open filesystem. Filesystem seems damaged."
The first partition (cylinder 0, head 1, sector 1) shows: "No file found, filesystem may be damaged."
Are there any chances to recover my data from my windows partition?
I would greatly appreciate any help.
Filesystem seems damaged. Windows partition missing
majkeltivoly
- testdisk.zip
- (2.48 KiB) Downloaded 555 times
Re: Filesystem seems damaged. Windows partition missing
Unfortunately, I can't read your log file.
How did you wipe your disk?
I've no idea about the disk size.
Did you run Deeper Search too?
majkeltivoly
Hi.
I uploaded log file again if there will be still problem to download it I don't know if I may put all the log text here.
It wasn't diskwipe by roadkil but could be similar one, I'm not sure.
I have 4 disks with 500 GB capacity set on RAID10.
Yes I did the deep search.
