I hope somebody here can help me with a partition problem on a 320GB usb external hard disk.
Originally the drive had two partitions, both with NTFS filesystem. The first partition was the largest and held all the data, the second was only 16 GB and was empty.
By mistake the disk was used to create a windows recovery media: a 32 GB FAT32 partition was created at the beginning of the disk leaving the rest unreadable.
TestDisk in quick scan and in deeper scan detects the 16 GB partition but not the first one (the one I need to recover...). It also detects a 104 GB partition from the backup boot which (I think) is a leftover of an old configuration.
Here is the log:
TestDisk 7.1-WIP, Data Recovery Utility, September 2015
OS: Linux, kernel 3.5.0-54-generic (#81~precise1-Ubuntu SMP Tue Jul 15 04:02:22 UTC 2014) x86_64
Compiler: GCC 4.4
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
/dev/sda: size 1250263728 sectors
/dev/sda: user_max 1250263728 sectors
/dev/sda: native_max 1250263728 sectors
/dev/sda: dco 1250263728 sectors
Disk /dev/sda - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - Hitachi HDT721064SLA360, S/N:STHDD7MG1XYG8Y, FW:STDOA31B
Disk /dev/sdd - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - Hitachi HTS543232L9A300
Disk /dev/sdd - 320 GB / 298 GiB - Hitachi HTS543232L9A300
New options :
Dump : No
Align partition: Yes
Expert mode : Yes
Analyse Disk /dev/sdd - 320 GB / 298 GiB - CHS 38913 255 63
FAT32 at 0/32/33
Info: size boot_sector 67108864, partition 67108864
FAT1 : 8196-16385
FAT2 : 16386-24575
start_rootdir : 24576 root cluster : 2
Data : 24576-67108863
sectors : 67108864
cluster_size : 64
no_of_cluster : 1048192 (2 - 1048193)
fat_length 8190 calculated 8190
1 * FAT32 LBA 0 32 33 4177 117 36 67108864 [RIPRISTINO]
FAT32 at 0/32/33
FAT1 : 8196-16385
FAT2 : 16386-24575
sectors : 67108864
cluster_size : 64
FAT32 at 0/32/33
FAT32, blocksize=32768, 34 GB / 32 GiB
NTFS at 36745/210/10
filesystem size 34816000
mftmirr_lcn 2
HPFS - NTFS 36745 210 10 38913 5 4 34816000
NTFS, blocksize=4096, 17 GB / 16 GiB
P HPFS - NTFS 36745 210 10 38913 5 4 34816000
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 67108864 linear /dev/sdd 2048" | dmsetup create test0
echo "0 34816000 linear /dev/sdd 590321664" | dmsetup create test1
ntfs_ucstoutf8: iconv_open failed
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 11-Oct-2015 12:34 .
5 dr-xr-xr-x 0 0 0 11-Oct-2015 12:34 ..
35 dr-xr-xr-x 0 0 0 11-Oct-2015 12:34 System Volume Information
1 P HPFS - NTFS 36745 210 10 38913 5 4 34816000
ntfs_mst_post_read_fixup_warn: magic: 0x032886f4 size: 1024 usa_ofs: 4362 usa_count: 5015: Invalid argument
Record 0 has no FILE magic (0x32886f4)
FAT32 at 0/32/33
FAT1 : 8196-16385
FAT2 : 16386-24575
sectors : 67108864
cluster_size : 64
FAT32 at 0/32/33
FAT32 at 0/32/39
FAT1 : 8196-16385
FAT2 : 16386-24575
sectors : 67108864
cluster_size : 64
FAT32 at 0/32/39
FAT32 LBA 0 32 33 4177 117 36 67108864 [NO NAME]
mftmirr_lcn 2
NTFS at 38912/254/63
filesystem size 205037595
mft_lcn 4
mftmirr_lcn 12814849
HPFS - NTFS 26150 0 1 38912 254 63 205037595
NTFS found using backup sector, blocksize=4096, 104 GB / 97 GiB
mft_lcn 4
HPFS - NTFS 38912 254 63 51675 254 62 205037595
NTFS, blocksize=4096, 104 GB / 97 GiB
This partition ends after the disk limits. (start=625137344, size=205037595, end=830174938, disk end=625142448)
NTFS at 38913/5/4
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 17 GB / 16 GiB
The harddisk (320 GB / 298 GiB) seems too small! (< 425 GB / 395 GiB)
echo "0 205037595 linear /dev/sdd 420099750" | dmsetup create test1
echo "0 34816000 linear /dev/sdd 590321664" | dmsetup create test2
Not an exFAT boot sector.
dir_partition inode=0
FAT: cluster=2(0x2), pos=26624
3 drwxr-xr-x 0 0 0 11-Oct-2015 12:35 EFI
55 -rwxr-xr-x 0 0 404250 14-Jun-2014 12:46 BOOTMGR
68 drwxr-xr-x 0 0 0 11-Oct-2015 12:35 BOOT
79 -rwxr-xr-x 0 0 1614168 14-Jun-2014 14:00 BOOTMGR.EFI
1076 drwxr-xr-x 0 0 0 11-Oct-2015 12:35 SOURCES
9362 drwxr-xr-x 0 0 0 11-Oct-2015 12:35 System Volume Information
983072 -rwxr-xr-x 0 0 1090 11-Oct-2015 05:15 REAGENT.XML
983142 drwxr-xr-x 0 0 0 12-Oct-2015 11:37 $RECYCLE.BIN
X 105 drwxr-xr-x 0 0 32768 12-Oct-2015 13:32 _168187_
X 105 drwxr-xr-x 0 0 32768 12-Oct-2015 15:11 MSId3986.tmp
X 105 drwxr-xr-x 0 0 32768 13-Oct-2015 13:10 MSI3c337.tmp
2 P HPFS - NTFS 26150 0 1 38912 254 63 205037595
TestDisk exited normally.I was able to recover something with qphotorec, but most of the important data was not recovered so I would like to try to fix the partition table if possible.
Any ideas on how I could try to fix the drive?
