Due to a bug created by Windows, I tried to rewrite the partitions of my hard disk with TestDisk. I had a Dual Boot environment (Windows / Ubuntu) and I had two Linux partitions (Partition type 83). A partition was with Ubuntu 13 and the other one with Ubuntu 15.04.
Although there is no overlap, I don't understand the reason why TestDisk refuses any structure that will contain my two Linux partitions: within the "Quick Search" screen, if I only select one of the two partitions, it says to me "Structure OK" but I try to select both Linux partitions, it says to me "Bad structure". May you help me?
When I try to select my two Linux partitions:
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63
P FAT32 LBA 0 32 33 3263 170 43 52428800 [RECOVERY]
* HPFS - NTFS 3263 170 44 39744 19 19 586057728 [OS]
P HPFS - NTFS 39744 19 20 51954 195 57 196164776 [DATA]
HPFS - NTFS 39744 19 20 51954 209 31 196165632 [DATA]
>L Linux 51954 209 32 70244 108 8 293822464
L Linux 70244 108 9 90445 190 49 324534272
L Linux Swap 90446 195 54 91201 52 51 12120064
Structure: Bad. Use Up/Down Arrow keys to select partition.
Enter: to continueubuntu@ubuntu:~$
ext4 blocksize=4096 Large file Sparse superblock, 150 GB / 140 GiB
When I try to only select my first Linux partition:
Keys A: add partition, L: load backup, T: change type,
Enter: to continue
SWAP2 version 1, pagesize=4096, 6205 MB / 5918 MiB
When I try to only select my second Linux partition:
Enter: to continue
ext4 blocksize=4096 Large file Sparse superblock, 166 GB / 154 GiB
