I am trying to recover files after a RAID array was mistakenly declared failed by Intel Rapid Storage Technology. After rebuilding the parition, I can see the list of my files when I use Undelete. However, when I try to actually undelete a file, I get "Record is in use by the mft" How would I get to fixing this?
Log file is as follows:
Fri Oct 23 21:31:54 2015
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=240063086592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4000792444928
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=4000787029504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=64016220160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=240063086592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000792444928
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4000787029504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=64016220160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239467495424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=64016203776
Disk /dev/sda - 240 GB / 223 GiB - CHS 29186 255 63, sector size=512
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Disk /dev/sdc - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Disk /dev/sdd - 64 GB / 59 GiB - CHS 7782 255 63, sector size=512
Drive C: - 239 GB / 223 GiB - CHS 29113 255 63, sector size=512
Drive D: - 4000 GB / 3725 GiB - CHS 486384 255 63, sector size=512
Drive G: - 64 GB / 59 GiB - CHS 7782 255 63, sector size=512
NTFS at 16/113/34
Error: size boot_sector 3518814208 > partition 4294967295
1 * HPFS - NTFS 16 113 34 267365 202 36 4294967295
Files with potentially recoverable content: 14944
*Snip a LOT of file names*
File undelete failing "Record is in use by the mft"
Re: File undelete failing "Record is in use by the mft"
You can have this message when the original file was fragmented or when new files have been written on the disk after the deletion.
If everything failed, you can try PhotoRec on the free space of the partition.
Good luck
Good luck
