RAW Hard Drive
Dysharmonic
Re: RAW Hard Drive
#11 Post by Dysharmonic »
The bootsector is bad, but the backup boot sector is fine; should I Backup BS? Will this get rid of my files?
[EDIT]; It says it can't overwrite the boot sector.
[EDIT]; It also hangs at Rebuild BS, even after waiting for 10+ hours.
allan
Re: RAW Hard Drive
#12 Post by allan »
Hi, I'm facing this same issue.
I'm trying to fix a boot sector from a virtual disk created with disk2vhd.
I activated the log on testdisk and found a more detailed error on it: No medium found.
Write new boot!
file_pwrite(9,1,buffer,63(0/1/1)) write err No medium found
Write error: Can't write new NTFS boot sector
file_pwrite(9,1,buffer,148360274(9234/254/63)) write err No medium found
Write error: Can't write new NTFS backup boot sector
I don't know other software that could fix the boot sector of my virtual disk.
If anyone has an idea of what's going on, please share!
Regards.
