Wrote the partition table thinking I'd fix it...
Re: Wrote the partition table thinking I'd fix it...
#11 Post by Fiona »
There are some little things to watch!
Exfat appears as a NTFS-partition but the file system is formatted as exfat.
TestDisk will only display a NTFS-partition and running on GPT as MS Data.
You should mark each MS Data partition and check the bottom of the display.
Example:
It's an NTFS partition ( because it's Intel MBR and not GPT, under GPT it's MS Data).
At the bootom of the screen you can watch it as an exfat-boot sector.
It's a tip to locate exfat better!
tomtailford
#12 Post by tomtailford »
I don't understand your reply (sorry!)
The disc used is a GRAID - which was formatted using a MacBook Pro and is exfat.
So I selected Intel/PC Partition (although it detected EFI GPT) and now I get this:
Is this good news?? Here's the log - any advice what to do next? THANKS FIONA!
Tue Dec  1 20:43:27 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=8001490518016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=8001490518016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=206158430208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=246994173952
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1500301908992
Disk /dev/sda - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512
Disk /dev/sdb - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Disk /dev/sdc - 8001 GB / 7451 GiB - CHS 972792 255 63, sector size=512
Drive C: - 206 GB / 192 GiB - CHS 25064 255 63, sector size=512
Drive D: - 246 GB / 230 GiB - CHS 30028 255 63, sector size=512
Drive G: - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Analyse Disk /dev/sdc - 8001 GB / 7451 GiB - CHS 972792 255 63
Geometry from i386 MBR: head=1 sector=1
BAD_RS LBA=1 16065
 1 P EFI GPT                  0   0  2 267349  89  4 4294967295
Bad relative sector.
file_pread(6,1,buffer,2743009280(972792/122/3)) ReadFile The drive cannot find the sector requested.
file_pread(6,14,buffer,2743009281(972792/122/4)) lseek err Invalid argument
file_pread(6,3,buffer,2743009295(972792/122/18)) lseek err Invalid argument
file_pread(6,3,buffer,2743009342(972792/123/2)) lseek err Invalid argument
file_pread(6,8,buffer,2743009358(972792/123/18)) lseek err Invalid argument
file_pread(6,11,buffer,2743009405(972792/124/2)) lseek err Invalid argument
file_pread(6,2,buffer,2743011327(972792/154/34)) lseek err Invalid argument
NTFS at 16/113/34
filesystem size           2048000
sectors_per_cluster       8
mft_lcn                   85333
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS             16 113 34   143 236 29    2048000
     NTFS, blocksize=4096, 1048 MB / 1000 MiB
     HPFS - NTFS             25 159  7 972792  89 33 15627497472
     exFAT, blocksize=262144, 8001 GB / 7451 GiB
file_pread(6,2,buffer,2743009280(972792/122/3)) ReadFile The drive cannot find the sector requested.
file_pread(6,2,buffer,2743009310(972792/122/33)) lseek err Invalid argument
file_pread(6,1,buffer,2743009310(972792/122/33)) lseek err Invalid argument
file_pread(6,2,buffer,2743009343(972792/123/3)) lseek err Invalid argument
file_pread(6,1,buffer,2743009343(972792/123/3)) lseek err Invalid argument
file_pread(6,2,buffer,2743009373(972792/123/33)) lseek err Invalid argument
file_pread(6,1,buffer,2743009373(972792/123/33)) lseek err Invalid argument
SIGINT detected! TestDisk has been killed.
#13 Post by Fiona »
Sry that you didn't understand it!
Will make an effort to guide you through.
On your picture, the second partition ist exFAT.
Did you select it and were you pressing p to have a try to list your files?
You should select this partition:
You can watch it here:
Please let me know, can you list your files?
Info will follow.
tomtailford
#14 Post by tomtailford »
Now it won't show that partition any more... from a quickscan I got:
quickscanresults
quickscanresults
Another thing you might want to know... when a mac formats an exfat drive it says this in windows:
Attempting to list files on this partition does this:
quickscanresults
quickscanresults
There is no option for list files on other partition.
Confused!
tomtailford
#15 Post by tomtailford »
I did create a backup (I think) and am able to load this - would you do this?
tomtailford
#16 Post by tomtailford »
So you know... this is what originally happened:
RAID 8TB (2x4TB striped raid) - EXFAT - showing up as RAW in windows / not showing partition in mac (only device)
Testdisk detects EFI GPT partition
Analysed - showed correct partition name (Chimp)
List files - showed all my files
Backup - saved current pariton list (not sure where I can find this on my MacBookPro?)
Wrote partition structure to disk (thinking it would fix)
List files - "support for this filesystem hasn't been implemented"
Says MacHFS? (Confusing as 99% sure it was exfat)
Backup - saved current partition list as follows:
#1447360813 Disk /dev/sdc - 8001 GB / 7451 GiB - CHS 972792 255 63
 1 : start=       40, size=   409600, Id=00, P
 2 : start=   409640, size=2742337456, Id=00, P
Please tell me I've not royally screwed myself :/
tomtailford
#17 Post by tomtailford »
Sorry, any ideas on this - have I crashed my raid?
Will I be able to recover? The files were visible before I wrote my partition table :(
tomtailford
#18 Post by tomtailford »
Any ideas on this please?
Sorry to bring up this old post but I've still got this drive sitting in my drawer and hoping for it to be recovered.
Is there any other ways of recovering this data?
