Hi
I recently had a Samsung Story 2TB external drive fail on me. I've tried testdisk, but think I've gone wrong somewhere and possibly written over something which is now causing the drive to not show up in Windows (it shows in Device Manager under disk drives as HDD USB Device, but doesn't show up in Disk Management or in Test Disk). The drive was initially at least showing in Windows, and therefore scan-able in testdisk.
Can anyone give me any pointers?
Test disk log attached. Thought I'd worked out where the problem was, but then managed to do something which has taken me two steps back so that I can't even see the drive now!
Thanks in advance for any help.
2TB external HDD
Re: 2TB external HDD
If the disk doesn't show up anymore, it's probably a hardware problem. In this case, you need to contact a data recovery company.
Thanks for replying. That's a shame that it sounds like a hardware problem. The drive was showing up perfectly before in Windows, device manager, and disk management. Now only in device manager.
Anyway, just in case it sheds any more light, here is the testdisk log (which I thought I'd attavched)
Sat Nov 14 12:25:40 2015
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2199023255552
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=801567145984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=127928369152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2199021158400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=801566097408
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=314567576064
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=685626407424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=2000396288512
Disk \\.\PhysicalDrive0 - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 2199 GB / 2048 GiB - CHS 267349 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 801 GB / 746 GiB - CHS 97451 255 63, sector size=512
Disk \\.\PhysicalDrive5 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive C: - 127 GB / 119 GiB - CHS 15553 255 63, sector size=512
Drive E: - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
Drive F: - 801 GB / 746 GiB - CHS 97451 255 63, sector size=512
Drive G: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive H: - 314 GB / 292 GiB - CHS 38243 255 63, sector size=512
Drive I: - 685 GB / 638 GiB - CHS 83355 255 63, sector size=512
Drive J: - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive5 - 2000 GB / 1863 GiB - CHS 243201 255 63
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 0 1 2 243200 254 63 3907024001
Error reading $MFT: Input/output error.
ntfs_mft_load(): Failed.
file_win32_pread(108,16,buffer,95(0/1/33)) read err: read after end of file
file_win32_pread(108,1,buffer,95(0/1/33)) read err: read after end of file
file_win32_pread(108,16,buffer,65(0/1/3)) read err: read after end of file
file_win32_pread(108,1,buffer,65(0/1/3)) read err: read after end of file
file_win32_pread(108,8,buffer,71(0/1/9)) read err: read after end of file
file_win32_pread(108,16,buffer,64(0/1/2)) read err: read after end of file
file_win32_pread(108,1,buffer,64(0/1/2)) read err: read after end of file
file_win32_pread(108,16,buffer,6160447(383/119/56)) read err: read after end of file
file_win32_pread(108,1,buffer,6160447(383/119/56)) read err: read after end of file
file_win32_pread(108,8,buffer,6160463(383/120/9)) read err: read after end of file
file_win32_pread(108,16,buffer,6291519(391/160/25)) read err: read after end of file
file_win32_pread(108,1,buffer,6291520(391/160/26)) read err: read after end of file
file_win32_pread(108,16,buffer,6291582(391/161/25)) read err: read after end of file
file_win32_pread(108,1,buffer,6291582(391/161/25)) read err: read after end of file
NTFS at 243200/254/63
filesystem size 3907024001
mftmirr_lcn 244189000
NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
NTFS: Can't read MFT
HPFS - NTFS 243200 254 63 486401 253 61 3907024001
This partition ends after the disk limits. (start=3907024064, size=3907024001, end=7814048064, disk end=3907029168)
The harddisk (2000 GB / 1863 GiB) seems too small! (< 4000 GB / 3726 GiB)
L HPFS - NTFS 0 1 2 243200 254 63 3907024001
file_win32_pread(108,16,buffer,6291520(391/160/26)) read err: read after end of file
file_win32_pread(108,1,buffer,6291521(391/160/27)) read err: read after end of file
Not an exFAT boot sector.
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended LBA 0 1 1 243200 254 63 3907024002
5 L HPFS - NTFS 0 1 2 243200 254 63 3907024001
$MFT has invalid magic.
file_win32_pread(108,16,buffer,69(0/1/7)) read err: read after end of file
file_win32_pread(108,1,buffer,69(0/1/7)) read err: read after end of file
file_win32_pread(108,16,buffer,49(0/0/50)) read err: read after end of file
file_win32_pread(108,16,buffer,50(0/0/51)) read err: read after end of file
file_win32_pread(108,16,buffer,51(0/0/52)) read err: read after end of file
file_win32_pread(108,16,buffer,52(0/0/53)) read err: read after end of file
file_win32_pread(108,16,buffer,53(0/0/54)) read err: read after end of file
file_win32_pread(108,16,buffer,54(0/0/55)) read err: read after end of file
file_win32_pread(108,16,buffer,55(0/0/56)) read err: read after end of file
file_win32_pread(108,16,buffer,56(0/0/57)) read err: read after end of file
file_win32_pread(108,16,buffer,57(0/0/58)) read err: read after end of file
file_win32_pread(108,16,buffer,58(0/0/59)) read err: read after end of file
file_win32_pread(108,16,buffer,59(0/0/60)) read err: read after end of file
file_win32_pread(108,16,buffer,60(0/0/61)) read err: read after end of file
file_win32_pread(108,16,buffer,61(0/0/62)) read err: read after end of file
file_win32_pread(108,16,buffer,62(0/0/63)) read err: read after end of file
file_win32_pread(108,16,buffer,63(0/1/1)) read err: read after end of file
interface_load
interface_load
write!
write_all_log_i386: CHS: 0/1/1,lba=63
ntfs_boot_sector
NTFS at 0/1/2
filesystem size 1763440303340643858 3907024001
sectors_per_cluster 96 8
mft_lcn 2457582888 786432
mftmirr_lcn 752161660 244189000
clusters_per_mft_record 110 -10
clusters_per_index_record 4 1
Status: Bad
Status: OK
Sectors are not identical.
ntfs_boot_sector
NTFS at 0/1/2
Status: Bad
Status: OK
rebuild_NTFS_BS
mft at 1953512000
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 244189000
New / Current boot sector
filesystem size 3907024001 1763440303340643858
sectors_per_cluster 8 96
mft_lcn 786432 2457582888
mftmirr_lcn 244189000 752161660
clusters_per_mft_record -10 110
clusters_per_index_record 1 4
ntfs_boot_sector
NTFS at 0/1/2
Status: Bad
Status: OK
ntfs_boot_sector
NTFS at 0/1/2
Status: Bad
Status: OK
I've decided to try installing the HD into my PC rather than running it on a USB dock. Now that I've put it in and I'm in Windows, it shows up in Device Manager (as it did with the USB dock), but this time it also partially recognises it in Device Manager. Specifically it gives me this
