Error mounting /dev/sdc1 at /media/rafal/TOSHIBA EXT:
Command-line `mount -t "ntfs" -o
"uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sdc1"
"/media/rafal/TOSHIBA EXT"' exited with non-zero exit status 13:
ntfs_mapping_pairs_decompress() failed: Input/output error
Failed to mount '/dev/sdc1': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a SoftRAID/FakeRAID
hardware. In the first case run chkdsk /f on Windows then reboot into Windows twice.
The usage of the /f parameter is very important! If the device is a SoftRAID/FakeRAID then
first activate it and mount a different device under the /dev/mapper/ directory,
(e.g. /dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation for more details.
On linux I can read all information from disk but without any data. Please see below:
# fdisk -l
Disk /dev/sdc: 2000.4 GB, 2000398931968 bytes
głowic: 255, sektorów/ścieżkę: 63, cylindrów: 243201, w sumie sektorów: 3907029164
Jednostka = sektorów, czyli 1 * 512 = 512 bajtów
Rozmiar sektora (logiczny/fizyczny) w bajtach: 512 / 512
Rozmiar we/wy (minimalny/optymalny) w bajtach: 512 / 512
Identyfikator dysku: 0xc881c7db
Urządzenie Rozruch Początek Koniec Bloków ID System
/dev/sdc1 * 2048 3907028991 1953513472 7 HPFS/NTFS/exFAT
# ntfsfix -b /dev/sdc1
Mounting volume... ntfs_mapping_pairs_decompress() failed: Input/output error
FAILED
Attempting to correct errors... ntfs_mapping_pairs_decompress() failed: Input/output error
FAILED
Failed to startup volume: Input/output error
Checking for self-located MFT segment... OK
Volume is corrupt. You should run chkdsk.
testdisk
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63
1 * HPFS - NTFS 0 32 33 243201 78 13 3907026944 [TOSHIBA EXT]
Status: OK
Status: OK
Sectors are identical.
A valid NTFS Boot sector must be present in order to access any data;
even if the partition is not bootable.
