1TB western digital My Disk 3.0 external that displayed as Raw when I plugged it into my windows 7 machine. Worked fine before and no abnormal sounds like clicks. I ran it through test disk, and when I analized the disk it said the size "seemed too small" and it wasn't able to locate any partitions even through a Deep Search. Rewriting a new MBR didn't work either. I suspect I may need to change geometry, but I haven't done that before and need a few extra opinions! I'll attach the log.
If it makes a difference, I'm in the middle of trying to recover two other SATA internal 2.5" drives and this was my backup. 3 hard drive crashes in a year? Thanks, Western Digital.
Mon Dec 7 13:58:41 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000097185792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000200994816
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive C: - 1000 GB / 931 GiB - CHS 121588 255 63, sector size=512
Drive E: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Analyse Drive E: - 1000 GB / 931 GiB - CHS 121600 255 63
Geometry from i386 MBR: head=102 sector=52
BAD_RS LBA=1920221984 1286028
check_part_i386 1 type 72: no test
BAD_RS LBA=1936028192 5737917
check_part_i386 2 type 6C: no test
1 P Sys=72 119528 74 3 232582 38 44 1816210284
Bad relative sector.
2 * Sys=6C 120512 46 15 242121 118 1 1953653108
BAD_RS LBA=938751927 28956
FAT32 LBA 58434 154 16 165423 242 29 1718783843
This partition ends after the disk limits. (start=938751927, size=1718783843, end=2657535769, disk end=1953517568)
NTFS at 121600/215/23
filesystem size 1953517568
mftmirr_lcn 2
HPFS - NTFS 0 0 1 121600 215 23 1953517568
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
Partition not added.
The harddisk (1000 GB / 931 GiB) seems too small! (< 1360 GB / 1267 GiB)
NTFS at 109851/213/58
filesystem size 1764769792
mftmirr_lcn 2
HPFS - NTFS 0 0 1 109851 213 58 1764769792
NTFS found using backup sector, blocksize=4096, 903 GB / 841 GiB
mftmirr_lcn 2
Change partition type:
New options :
Dump : No
Align partition: Yes
Expert mode : No
A new copy of MBR code has been written.
You have to reboot for the change to take effect.
Disk size seems too small; no recoverable partitions
Re: Disk size seems too small; no recoverable partitions
Select Disk /dev/sdb, Advanced, Boot, RebuildBS. If you see your files, choose Write, confirm, Quit, restart your computer.
And if I can't see my files? (Can't open filesystem, filesystem seems damaged)
