SD repair
narush2015
SD repair
#1 Post by narush2015 »
After I recover all my files will I ever be able to use the SD card? Thanks for the help
Re: SD repair
You can do what you want once your files have been recovered: write new file, reformat the memory card...
narush2015
Re: SD repair
#3 Post by narush2015 »
I have attempted to reformat RAW file SD to a FAT32 but command prompt says the disk has bad sectors and cannot be guaranteed to have been cleaned. Also says invalid media or Track 0 bad - disk unusable. Is there anyway to fix this or do i toss the card and buy a new one.....BTW its a Samsung EVO 32GB micro SD card
