TestDisk appears Partition : Read error
jk22
Re: TestDisk appears Partition : Read error
#11 Post by jk22 »
I have used many datarecovery but find nothing. I think file system is damaged or only MBR is not readable?
Can you tell me how to clone a RAW drive ?
jk22
#12 Post by jk22 »
I am using Ubuntu from USB Flash Drive and its showing me all data and it makes me happy but when I try to copy its say
there was an error copying the file into /media/ubuntu/Local Disk
Moreover, every data which I copied to other drive showing 0 bytes instead of notepad files which are showing actual size and working good.
jk22
#13 Post by jk22 »
Problem fixed. :)
#14 Post by Fiona »
Did you create an overlay on your USB flash drive to copy data to?
You should run a terminal as superuser like:
sudo -s
How did you solve your issue?
jk22
#15 Post by jk22 »
I have used Live USB and it shows me RAW partitions. :)
#16 Post by Fiona »
Thanks for your feedback!
jk22
#17 Post by jk22 »
By the way can I fix partition tables with testdisk ?
techrich
#18 Post by techrich »
Hi JK22
Can you detail the process for recovery that you have followed in getting this harddrive back?
I am in the same state as in you. Appreciate all your help.
Thanks
