Win + photorec + image split = Error
jtrigueros
win + photorec + split dd = Unable to open file
#1 Post by jtrigueros »
Hi everybody,
I've one image (format DD) splited (image.001, image.002, etc.)
When i execute photorec with below parameters:
photorec_win.exe /d C:\TEMP\CARVER\image /cmd C:\DD_FILES\IMAGE.???
or
photorec_win.exe /d C:\TEMP\CARVER\image /cmd C:\DD_FILES\IMAGE.*
Photorec show below ouput:
Unable to open file or device C:\DD_FILES\IMAGE.???: Invalid argument
or
Unable to open file or device C:\DD_FILES\IMAGE.*: Invalid argument
I've tried with quotes, without quotes, change backslash for slash, etc. but it always show same error.
Any help will be appreciate :D
Thanks
jtrigueros
#2 Post by jtrigueros »
Hi Everybody,
I've one image (format DD) split as follows: (image.001, image.002, etc.)
When i execute photorec with the parameters below:
photorec_win.exe /d C:\TEMP\CARVER /cmd C:\DD_FILES\IMAGE.???
or
photorec_win.exe /d C:\TEMP\CARVER /cmd C:\DD_FILES\IMAGE.*
Photorec shows the output below:
or
I've tried with quotes, without quotes, changing the backslash for slash, etc. but it always shows the same error.
Any ideas?
Thanks
Re: Win + photorec + image split = Error
#3 Post by cgrenier »
Splitted raw/dd files are not supported.
You have to concat the files.
type C:\DD_FILES\IMAGE.* > C:\DD_FILES\FULL.DD
Note that if you have a image.txt or image.md5, you need to move the files somewhere else before using the command.
