My laptop hard drive is inaccessible , i disconected it and connected it via a external housing . Its not being picked up in windows explorer , but I'm able to see it in TestDisk
It says that the file system is RAW
Those messages are not as bad!
TestDisk usually works Intel Standard.
Microsoft changed the partition layout from cylinder boundary to megabyte boundary (Intel partitions are aligned on cylinder boundary).
That's why TestDisk complaines.
But it looks like that your partition is in your partition table.
A boot sector diagnose doesn't stress your disk as much.
TestDisk is able to copy files from a damaged file system, even if windows doesn't display any file.
Please have a try;
Select your second and large partition.
Confirm at Boot.
Please upload another schreenshot.
If you see the menu List, please have have a try to list your data.
If you were not able to list your data or TestDisk displays an error message;
If you're able to list your data, copy/backup them to another intact partition or disk.
At the bottom of the screen you'll find all the commands.
To go into any folder you can check it and use your right arrow on your keyboard.
To get one directory up, check that 2 dots and press enter.
Standard path is your testdisk folder.
