FAT32 with Linux . help requested
bhavna31sharma
#1 Post by bhavna31sharma »
following happened when i tried recovering 1tb hdd
Two same *FAT partitions found
Results after Quick search
results after quick search and P used to see files showed
"Support for this file system hasnt been enable during compilation"
results after deep search
finally no partitions shown and same msg displayed
please help ... do i have to go to professionals forgetting data back
Re: FAT32 with Linux . help requested
Can you use TestDisk 7.1WIP 32bit and under disk selection, can you select your disk instead of PhysicallyDrive?
Looks like Disk /dev/sd* (*= a, b, c, etc..).
There ar not 2 partitions in your partition table.
The current partition in your partition table is a FAT16 >32MB and probably wrong?
It's listed twice because there is a message that your FATn boot sector is not valid (message is related to this partition).
What partition and file system are you looking for?
Run another diagnose with testdisk 32bit and copy and paste the content of your testdisk.log into your next post.
