Need help with recovering a partition
Gonzo
#1 Post by Gonzo »
Hello everyone! I'm a beginner with testdisk and need a little help with recovering my lost partition.
I was installing Ubuntu 15.10 and i wanted to use my existing luks-encrypted partition as /home. I activated encrypted volume, set mapped device to 'use as ext4...' and mount under /home, and of course not to format. After approving changes installer crashed and ended installation messing something with partition table. I googled how to use testdisk and thats what I got:
When selecting Intel partition table type (like it was before) analyse doesn't show any partition table and the quicksearch finds a bunch of FAT and NTFS partitions with some 'files' made of random characters. Here's logfile
Fri Jan  8 10:39:21 2016
OS: Linux, kernel 3.19.0-15-generic (#15-Ubuntu SMP Thu Apr 16 23:32:01 UTC 2015) i686
Compiler: GCC 4.9
Compilation date: 2015-04-03T09:01:56
ext2fs lib: 1.42.12, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size       234490943 sectors
/dev/sda: user_max   234490943 sectors
/dev/sda: native_max 234493056 sectors
/dev/sda: dco        234493056 sectors
/dev/sdb: size       976771055 sectors
/dev/sdb: user_max   976771055 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sdb: dco        976773168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size       3907029168 sectors
/dev/sdc: user_max   3907029168 sectors
/dev/sdc: native_max 3907029168 sectors
/dev/sdc: dco        3907029168 sectors
/dev/sr0 is not an ATA disk
Disk /dev/sda - 120 GB / 111 GiB - CHS 14596 255 63, sector size=512 - SAMSUNG SP1213C, S/N:S02AJ10Y113436, FW:SV100-34
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - HDS725050KLA360, S/N:KRVN65ZAJMMLRF, FW:K2AOAD1A
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-1CH164, S/N:Z340PWET, FW:CC29
Disk /dev/mapper/sejf - 500 GB / 465 GiB - 976762880 sectors, sector size=512
Disk /dev/sr0 - 729 MB / 696 MiB - 356352 sectors (RO), sector size=2048 - GCR-8523B, FW:1.00
Disk /dev/dm-0 - 500 GB / 465 GiB - 976762880 sectors, sector size=512
Analyse Disk /dev/mapper/sejf - 500 GB / 465 GiB - 976762880 sectors
block_group_nr 1
recover_EXT2: part_offset problem
block_group_nr 1
recover_EXT2: s_block_group_nr=1/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 122095360
recover_EXT2: part_size 976762880
     Linux                          0  976762879  976762880 [Sejf]
     ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 500 GB / 465 GiB
Partition not added.
block_group_nr 3
block_group_nr 3
recover_EXT2: s_block_group_nr=3/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
block_group_nr 25
recover_EXT2: s_block_group_nr=25/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
BAD_RS LBA=105774612 550
     FAT12                  105774612 3306160149 3200385538
This partition ends after the disk limits. (start=105774612, size=3200385538, end=3306160149, disk end=976762880)
BAD_RS LBA=3541669149 1027
     FAT32 LBA             3541669149 7170565750 3628896602
This partition ends after the disk limits. (start=3541669149, size=3628896602, end=2875598454, disk end=976762880)
BAD_RS LBA=2383693206 332
     FAT16 >32M            2383693206 5105223869 2721530664
This partition ends after the disk limits. (start=2383693206, size=2721530664, end=810256573, disk end=976762880)
BAD_RS LBA=3889834453 1027
     FAT16 >32M            3889834453 4004128021  114293569
This partition ends after the disk limits. (start=3889834453, size=114293569, end=4004128021, disk end=976762880)
BAD_RS LBA=1251110765 923
     FAT16 >32M            1251110765 5150083202 3898972438
This partition ends after the disk limits. (start=1251110765, size=3898972438, end=855115906, disk end=976762880)
block_group_nr 49
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
BAD_RS LBA=564398619 640
     FAT12                  564398619 1811201104 1246802486
This partition ends after the disk limits. (start=564398619, size=1246802486, end=1811201104, disk end=976762880)
BAD_RS LBA=1103837831 250
     FAT32 LBA             1103837831 4502338453 3398500623
This partition ends after the disk limits. (start=1103837831, size=3398500623, end=207371157, disk end=976762880)
BAD_RS LBA=1725146942 334
     HPFS - NTFS           1725146942 4794054566 3068907625
This partition ends after the disk limits. (start=1725146942, size=3068907625, end=499087270, disk end=976762880)
BAD_RS LBA=4271271889 1163
     FAT16 >32M            4271271889 4716971893  445700005
This partition ends after the disk limits. (start=4271271889, size=445700005, end=422004597, disk end=976762880)
BAD_RS LBA=1951290925 396
     FAT12                 1951290925 3991799773 2040508849
This partition ends after the disk limits. (start=1951290925, size=2040508849, end=3991799773, disk end=976762880)
BAD_RS LBA=3758318374 522
     FAT32                 3758318374 3983168192  224849819
This partition ends after the disk limits. (start=3758318374, size=224849819, end=3983168192, disk end=976762880)
block_group_nr 81
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
BAD_RS LBA=1385760642 1161
     FAT16 <32M            1385760642 1542554290  156793649
This partition ends after the disk limits. (start=1385760642, size=156793649, end=1542554290, disk end=976762880)
BAD_RS LBA=1146847928 112
     FAT12                 1146847928 1990696128  843848201
This partition ends after the disk limits. (start=1146847928, size=843848201, end=1990696128, disk end=976762880)
BAD_RS LBA=895642502 338
     FAT12                  895642502 3181413127 2285770626
This partition ends after the disk limits. (start=895642502, size=2285770626, end=3181413127, disk end=976762880)
block_group_nr 125
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/3726, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
BAD_RS LBA=1473623938 484
     FAT16 <32M            1473623938 5296133852 3822509915
This partition ends after the disk limits. (start=1473623938, size=3822509915, end=1001166556, disk end=976762880)
BAD_RS LBA=1485074010 397
     FAT12                 1485074010 1706532601  221458592
This partition ends after the disk limits. (start=1485074010, size=221458592, end=1706532601, disk end=976762880)
BAD_RS LBA=48809146 993
     FAT16 LBA               48809146  874090643  825281498
BAD_RS LBA=4269127312 445
     HPFS - NTFS           4269127312 8042097481 3772970170
This partition ends after the disk limits. (start=4269127312, size=3772970170, end=3747130185, disk end=976762880)
BAD_RS LBA=2636759912 1220
     FAT16 <32M            2636759912 4113908184 1477148273
This partition ends after the disk limits. (start=2636759912, size=1477148273, end=4113908184, disk end=976762880)
BAD_RS LBA=270934130 1039
     FAT16 LBA             4565901426 5749224824 1183323399
This partition ends after the disk limits. (start=270934130, size=1183323399, end=1454257528, disk end=976762880)
BAD_RS LBA=2495808880 1264
     FAT12                 2495808880 2745317033  249508154
This partition ends after the disk limits. (start=2495808880, size=249508154, end=2745317033, disk end=976762880)
BAD_RS LBA=3867257236 1038
     FAT16 >32M            3867257236 4970573082 1103315847
This partition ends after the disk limits. (start=3867257236, size=1103315847, end=675605786, disk end=976762880)
BAD_RS LBA=3784403913 748
     FAT16 >32M            3784403913 4983620463 1199216551
This partition ends after the disk limits. (start=3784403913, size=1199216551, end=688653167, disk end=976762880)
BAD_RS LBA=2845207624 380
     FAT32 LBA             2845207624 5546276340 2701068717
This partition ends after the disk limits. (start=2845207624, size=2701068717, end=1251309044, disk end=976762880)
BAD_RS LBA=1312215140 563
     FAT32 LBA             1312215140 4918696566 3606481427
This partition ends after the disk limits. (start=1312215140, size=3606481427, end=623729270, disk end=976762880)
BAD_RS LBA=547096510 188
     FAT16 LBA             4842063806 7948913021 3106849216
This partition ends after the disk limits. (start=547096510, size=3106849216, end=3653945725, disk end=976762880)
BAD_RS LBA=1267312992 1274
     FAT32                 1267312992 1821956274  554643283
This partition ends after the disk limits. (start=1267312992, size=554643283, end=1821956274, disk end=976762880)
BAD_RS LBA=3730575081 750
     FAT16 LBA             3730575081 4608661431  878086351
This partition ends after the disk limits. (start=3730575081, size=878086351, end=313694135, disk end=976762880)
BAD_RS LBA=1365727531 682
     FAT12                 1365727531 5314558491 3948830961
This partition ends after the disk limits. (start=1365727531, size=3948830961, end=1019591195, disk end=976762880)
BAD_RS LBA=3508478652 834
     HPFS - NTFS           3508478652 4438778101  930299450
This partition ends after the disk limits. (start=3508478652, size=930299450, end=143810805, disk end=976762880)
BAD_RS LBA=12604022 751
     HPFS - NTFS           4307571318 8556686492 4249115175
This partition ends after the disk limits. (start=12604022, size=4249115175, end=4261719196, disk end=976762880)
BAD_RS LBA=227886176 562
     FAT16 >32M            4522853472 8697138924 4174285453
This partition ends after the disk limits. (start=227886176, size=4174285453, end=107204332, disk end=976762880)
BAD_RS LBA=1868276443 1091
     FAT12                 1868276443 3235062764 1366786322
This partition ends after the disk limits. (start=1868276443, size=1366786322, end=3235062764, disk end=976762880)
BAD_RS LBA=2694107841 425
     FAT16 >32M            2694107841 6324011430 3629903590
This partition ends after the disk limits. (start=2694107841, size=3629903590, end=2029044134, disk end=976762880)
BAD_RS LBA=2682983724 184
     FAT32                 2682983724 3211048073  528064350
This partition ends after the disk limits. (start=2682983724, size=528064350, end=3211048073, disk end=976762880)
BAD_RS LBA=1191706235 652
     FAT16 <32M            1191706235 1234915884   43209650
This partition ends after the disk limits. (start=1191706235, size=43209650, end=1234915884, disk end=976762880)
BAD_RS LBA=727384809 373
     FAT16 <32M            5022352105 6565861148 1543509044
This partition ends after the disk limits. (start=727384809, size=1543509044, end=2270893852, disk end=976762880)
BAD_RS LBA=1165322179 552
     FAT16 LBA             1165322179 3439322116 2273999938
This partition ends after the disk limits. (start=1165322179, size=2273999938, end=3439322116, disk end=976762880)
BAD_RS LBA=1715623885 387
     FAT16 <32M            1715623885 3566696383 1851072499
This partition ends after the disk limits. (start=1715623885, size=1851072499, end=3566696383, disk end=976762880)
BAD_RS LBA=558145631 1173
     FAT32                 4853112927 5677805083  824692157
This partition ends after the disk limits. (start=558145631, size=824692157, end=1382837787, disk end=976762880)
BAD_RS LBA=3840870877 442
     FAT32                 3840870877 7025574124 3184703248
This partition ends after the disk limits. (start=3840870877, size=3184703248, end=2730606828, disk end=976762880)
BAD_RS LBA=362388339 967
     FAT16 LBA             4657355635 5415054097  757698463
This partition ends after the disk limits. (start=362388339, size=757698463, end=1120086801, disk end=976762880)
BAD_RS LBA=577488183 599
     FAT16 >32M            4872455479 6282233148 1409777670
This partition ends after the disk limits. (start=577488183, size=1409777670, end=1987265852, disk end=976762880)
BAD_RS LBA=2566402940 946
     FAT12                 2566402940 2955747027  389344088
This partition ends after the disk limits. (start=2566402940, size=389344088, end=2955747027, disk end=976762880)
BAD_RS LBA=670649569 944
     FAT32                 4965616865 8329578415 3363961551
This partition ends after the disk limits. (start=670649569, size=3363961551, end=4034611119, disk end=976762880)
BAD_RS LBA=3152127480 399
     FAT32 LBA             3152127480 5126327978 1974200499
This partition ends after the disk limits. (start=3152127480, size=1974200499, end=831360682, disk end=976762880)
BAD_RS LBA=1328652894 956
     FAT16 LBA             1328652894 1896009541  567356648
This partition ends after the disk limits. (start=1328652894, size=567356648, end=1896009541, disk end=976762880)
BAD_RS LBA=484239015 968
     FAT32 LBA             4779206311 5534448824  755242514
This partition ends after the disk limits. (start=484239015, size=755242514, end=1239481528, disk end=976762880)
BAD_RS LBA=680569519 1073
     FAT16 LBA             4975536815 5845696983  870160169
This partition ends after the disk limits. (start=680569519, size=870160169, end=1550729687, disk end=976762880)
BAD_RS LBA=1930292454 1226
Buffer can't store more than 200 lines.
     FAT16 >32M            1930292454 2184540115  254247662
This partition ends after the disk limits. (start=1930292454, size=254247662, end=2184540115, disk end=976762880)
BAD_RS LBA=1438868021 146
     FAT32                 1438868021 1749395113  310527093
This partition ends after the disk limits. (start=1438868021, size=310527093, end=1749395113, disk end=976762880)
BAD_RS LBA=1048817983 1005
     FAT16 LBA             1048817983 3040018824 1991200842
This partition ends after the disk limits. (start=1048817983, size=1991200842, end=3040018824, disk end=976762880)
BAD_RS LBA=865347428 667
     HPFS - NTFS           5160314724 6444575553 1284260830
This partition ends after the disk limits. (start=865347428, size=1284260830, end=2149608257, disk end=976762880)
BAD_RS LBA=3370459067 950
     HPFS - NTFS           3370459067 3938869081  568410015
This partition ends after the disk limits. (start=3370459067, size=568410015, end=3938869081, disk end=976762880)
BAD_RS LBA=3691159843 691
     FAT16 >32M            3691159843 7009609611 3318449769
This partition ends after the disk limits. (start=3691159843, size=3318449769, end=2714642315, disk end=976762880)
BAD_RS LBA=2127533795 1127
     FAT32                 2127533795 3733689684 1606155890
This partition ends after the disk limits. (start=2127533795, size=1606155890, end=3733689684, disk end=976762880)
The harddisk (500 GB / 465 GiB) seems too small! (< 4452 GB / 4147 GiB)
get_geometry_from_list_part_aux head=1 nbr=2
   * FAT16 LBA               48809146  874090643  825281498
dir_partition inode=0
 245135797 dr-xr-xr-x     0      0 3482360268 11-Dec-1919 00:55 5��%"��.�>m
 257032965 drwxr-xr-x     0      0 3946522400 25-Nov-1919 17:39 a�"�hY.
 233854360 drwxr-xr-x     0      0 2955490919 19-Jan-1952 17:32 �KO
 206517475 -r-xr-xr-x     0      0 2376684228 17-Jan-2036 01:38 ��l8�#�.{�`
 242748641 -rwxr-xr-x     0      0 1379039898 13-Jan-1980 13:34 3��1�	z�.�=u
 171116954 dr-xr-xr-x     0      0 3835712460 28-May-2012 20:58 �?%�%��.L�
 78229843 -rwxr-xr-x     0      0  49004801 21-Jun-2008 19:12 �i��T
 158143968 drwxr-xr-x     0      0 2676443504 13-Jul-1948 00:21 6v��D.@�)
 264954369 -rwxr-xr-x     0      0 3719195866 31-May-1956 05:37 y�d�H�.�
 5780556 drwxr-xr-x     0      0 4164412696 26-May-2030 09:56 �F�c��.K@
 1 * FAT16 LBA               48809146  874090643  825281498
Store new MBR code
Note that search finds the lost partition but says "Partition not added". Secondly I chose None as partition table, then analyse and quick search find partition properly and very quick but when I try to list files I get "No file found, filesystem may be damaged." Log gives "ext2fs_dir_iterate failed with error 2133571387":
Fri Jan  8 12:03:15 2016
Compiler: GCC 4.9
Partition table type: None
   P ext4                           0  976762879  976762880 [Sejf]
block_group_nr 1
block_group_nr 1
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571387.
Write isn't available because the partition table type "None" has been selected.
I think I should choose Intel type partition table and enter partition parameters manually, but I don't know how to do it and I don't want to make even bigger mess.
The whole disk is encrypted with LUKS and has only one primary ext4 partition labeled "Sejf". I'm sure the data is still there because ubuntu installer crashed without any disk writing activity.
I'd really appreciate any help.
Re: Need help with recovering a partition
If /dev/mapper/sejf is the unlocked LUKS filesystem, run as root
e2fsck -b 98304 -B 4096 /dev/mapper/sejf
Gonzo
#3 Post by Gonzo »
I'm afraid that won't do any good. I tried fsck with -n option, it throws output like this for hours:
# e2fsck -n -b 98304 -B 4096 /dev/mapper/sejf | more
e2fsck 1.42.12 (29-Aug-2014)
Sejf nie był czysto odmontowany, wymuszono sprawdzenie.
Przebieg 1: Sprawdzanie i-węzłów, bloków i rozmiarów
Przebieg 2: Sprawdzanie struktury katalogów
Przebieg 3: Sprawdzanie łączności katalogów
Przebieg 4: Sprawdzanie liczników odwołań
Przebieg 5: Sprawdzanie sumarycznych informacji o grupach
Różnice bitmapy bloków:  -24543232 -(24543234--24543235) -24543237 -24543240 -24543243 -(24543245--24543246) -24543248 -
24543250 -24543254 -(24543264--24543265) -(24543267--24543268) -(24543271--24543273) -(24543277--24543279) -(24543281--2
4543282) -24543287 -24543292 -24543297 -(24543299--24543300) -24543303 -(24543305--24543307) -24543309 -(24543316--24543
317) -(24543324--24543328) -24543333 -(24543342--24543343) -24543346 -24543348 -(24543350--24543351) -(24543353--2454335
9) -(24543366--24543369) -24543372 -(24543374--24543376) -24543378 -24543380 -24543383 -24543385 -24543387 -24543390 -(2
4543393--24543396) -24543399 -24543401 -(24543403--24543404) -24543408 -24543410 -(24543414--24543415) -(24543418--24543
422) -(24543424--24543427) -24543432 -(24543434--24543440) -24543443 -(24543445--24543449) -(24543451--24543457) -(24543
459--24543460) -24543462 -24543464 -24543470 -24543472 -24543475 -24543478 -24543481 -(24543483--24543484) -(24543488--2
4543489) -24543491 -24543493 -(24543496--24543499) -(24543503--24543505) -(24543508--24543509) -24543511 -24543519 -(245
43521--24543522) -(24543526--24543527) -24543530 -(24543533--24543534) -24543537 -(24543539--24543540) -(24543543--24543
545) -24543548 -24543551 -24543555 -24543557 -(24543560--24543561) -24543563 -24543566 -(24543568--24543569) -(24543572-
-24543573) -24543576 -24543578 -24543580 -24543582 -(24543587--24543588) -24543590 -24543597 -24543602 -24543604 -(24543
607--24543610) -24543612 -(24543615--24543616) -(24543618--24543621) -(24543624--24543625) -(24543627--24543629) -(24543
632--24543634) -(24543637--24543641) -24543643 -(24543647--24543649) -(24543651--24543652) -24543656 -(24543658--2454366
0) -24543663 -24543670 -24543672 -(24543674--24543675) -24543677 -24543680 -24543683 -(24543687--24543693) -24543695 -(2
4543697--24543700) -(24543704--24543708) -(24543710--24543714) -24543716 -(24543718--24543720) -24543724 -24543727 -2454
3730 -24543732 -(24543734--24543737) -24543739 -24543743 -24543745 -(24543750--24543751) -(24543753--24543754) -(2454375
9--24543762) -24543767 -24543770 -24543772 -(24543774--24543775) -24543779 -(24543783--24543785) -24543787 -24543791 -(2
4543794--24543795) -24543798 -24543802 -(24543804--24543805) -24543807 -24543809 -(24543812--24543814) -24543817 -245438
23 -24543826 -24543828 -(24543831--24543832) -(24543836--24543837) -24543842 -(24543844--24543845) -24543849 -24543852 -
(24543856--24543857) -24543860 -(24543862--24543865) -24543867 -24543872 -24543874 -(24543878--24543879) -(24543882--245
43884) -24543886 -24543888 -24543890 -24543900 -24543902 -24543913 -24543915 -(24543919--24543921) -(24543924--24543925)
 -(24543927--24543933) -(24543935--24543937) -24543939 -(24543941--24543943) -(24543945--24543946) -(24543948--24543952)
 -24543954 -24543956 -24543960 -24543963 -(24543965--24543966) -(24543968--24543970) -(24543973--24543974) -24543977 -(2
4543981--24543982) -(24543984--24543985) -(24543989--24543990) -24543992 -(24543998--24543999) -24544001 -24544003 -2454
4010 -24544012 -24544014 -24544016 -24544019 -24544021 -24544026 -(24544030--24544031) -(24544034--24544037) -(24544041-
-24544043) -(24544049--24544055) -24544057 -(24544059--24544063) -24544069 -24544073 -24544076 -24544079 -(24544082--245
44083) -(24544085--24544086) -24544088 -24544093 -(24544098--24544100) -(24544102--24544104) -(24544106--24544114) -(245
44118--24544119) -24544121 -24544124 -24544126 -24544128 -(24544131--24544133) -24544135 -(24544137--24544138) -(2454414
3--24544144) -(24544146--24544148) -24544151 -24544153 -24544157 -(24544159--24544160) -(24544165--24544166) -24544169 -
24544171 -(24544173--24544174) -24544176 -(24544179--24544184) -24544191 -(24544193--24544194) -24544198 -(24544200--245
44201) -24544205 -(24544208--24544211) -(24544220--24544222) -24544225 -24544227 -24544230 -(24544232--24544236) -245442
38 -24544242 -(24544245--24544246) -24544250 -24544252 -(24544254--24544256) -24544258 -24544261 -(24544266--24544267) -
