Cannot recover SD card
The other morning I found that my phone (a Samsung S6) suddenly stopped recognising my SD card - it says "unrecognised file system." I plugged it into an SD card reader but my PC also won't recognise it. Photorec and Testdisk both return absolutely nothing. If they recovered only small fragments I'd give up on it, but finding nothing at all sounds like there's some sort of filesystem error or encryption which isn't being recognised. Can anyone give me any tips on this?
Re: Cannot recover SD card
Is the card detected by PhotoRec ? Is the capacity correct ?
Run TestDisk, Adavnced, Image Creation. Compress the image.dd file (ie. zip). What is the resulting filesize ?
Card is detected, yes. The capacity looks right - 8gb - but I have no idea what the partition type should be for an SD card from an Android phone. Have tried a few, but it can't seem to find any file system with any of them - so can't do image creation.
Phones on android, regularly formatting an external sd card to Fat32 LBA.
Can you run a diagnose and copy and paste the content of your testdisk.log?
Sorry if I'm being slow here - I can't run a diagnose if I can't find a partition, can I? Anyway, I selected the SD card, , [Intel], [Analyse], [Quick search], [Deeper search], again found nothing, here's the log file.
Mon Jan 11 19:26:50 2016
TestDisk 7.1-WIP, Data Recovery Utility, January 2016
Compiler: GCC 4.9, Cygwin32 2002.0
Compilation date: 2016-01-07T18:42:01
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=8002732032
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=8002732032
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=304237338624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=8002732032
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD32 00BEVT-75A23, S/N:W -DXW12AAY05583, FW:01.0
Disk /dev/sdb - 8002 MB / 7632 MiB - CHS 972 255 63, sector size=512 - Mass Storage Device, FW:1.00
Disk /dev/sdb - 8002 MB / 7632 MiB - Mass Storage Device
Analyse Disk /dev/sdb - 8002 MB / 7632 MiB - CHS 972 255 63
file_pread(5,1,buffer,15630337(972/240/38)) lseek err Invalid argument
file_pread(5,14,buffer,15630338(972/240/39)) lseek err Invalid argument
file_pread(5,3,buffer,15630352(972/240/53)) lseek err Invalid argument
file_pread(5,3,buffer,15630399(972/241/37)) lseek err Invalid argument
file_pread(5,8,buffer,15630415(972/241/53)) lseek err Invalid argument
file_pread(5,11,buffer,15630462(972/242/37)) lseek err Invalid argument
file_pread(5,2,buffer,15632384(973/18/6)) lseek err Invalid argument
