I am attempting to copy a huge amount of photos and videos form a 3TB external hard drive to another external hard drive.
So far the program appears to be successfully copying over most photos but I am only getting small parts of videos copied over.
I have video files that range in size from a few hundred MB to several GB but TestDisk is only copying a small portion of each video file. I'm only getting a few MB from each video file copied over.
Any suggestions? Any help would be greatly appreciated.
Thanks.
Copy Files - Only Part of Video Files Copied
Re: Copy Files - Only Part of Video Files Copied
What is the source filesystem type ? (NTFS, exFAT, FAT32, ext2/3/4...)
What is the destination filesystem type ?
Which version are you using ? (7.0, 7.1-WIP, dos, windows 32 bits, windows 64 bits, Linux, Mac OSX)
whiskyandspice
Thank you for your assistance.
The source filesystem type is RAW.
The destination filesystem type is NTFS
I am using Windows 64 bit.
Much appreciated.
Much appreciated.
