Filesystem RAW instead of NTFS
nsantinho
#1 Post by nsantinho »
Good morning,
Had a problem with my HDD and now can't access it to backup my files... it was running CHKDSK and during it the PC rebboted and after that couldn't use the HDD any more. I run Testdisk and need some help with the results because can't find anything similar in the forums.
Hope anyone would be able to help me with this... ;)
The"deeper search" results are in the attached file...
Thx in advance,
Nuno Santinho
MonsterMMORPG
Re: Filesystem RAW instead of NTFS
#2 Post by MonsterMMORPG »
i have the same problem
i see no one answered :(
i can see and reach files but file system is still raw :(
