Corrupt superblock or partition table
SirDakkon
#1 Post by SirDakkon »
I have some problems with the partitions on my NAS (QNAP 431) and I wonder whether Testdisk might be able to solve it.
What happened?
I migrated from an RAID 1 setup to an RAID 5 setup (not via shell but via an NAS inbuilt GUI). On a first glance everything seems to be ok.
mdadm --detail /dev/md1
        Version : 1.0
  Creation Time : Thu Dec 31 01:56:55 2015
     Raid Level : raid5
     Array Size : 5840623232 (5570.05 GiB 5980.80 GB)
  Used Dev Size : 2920311616 (2785.03 GiB 2990.40 GB)
   Raid Devices : 3
  Total Devices : 3
    Persistence : Superblock is persistent
    Update Time : Tue Jan  5 19:23:37 2016
          State : clean
 Active Devices : 3
Working Devices : 3
 Failed Devices : 0
  Spare Devices : 0
         Layout : left-symmetric
     Chunk Size : 64K
           UUID : 553fe61b:9f23ed34:d2d6c2d4:9b2a59cf
         Events : 10759
    Number   Major   Minor   RaidDevice State
       0       8        3        0      active sync   /dev/sda3
       2       8       19        1      active sync   /dev/sdb3
       3       8       35        2      active sync   /dev/sdc3
However, I am not longer able to mount the volume.
[/] # mdadm -A /dev/md1 /dev/sd[a-c]3
mdadm: /dev/sda3 is busy - skipping
mdadm: /dev/sdb3 is busy - skipping
mdadm: /dev/sdc3 is busy - skipping
I did some googling and a helpful person from the qnap forums (thread is in german) suggested that the RAID is active but most probably has a broken filesystem due to errors during the resize.
[/] # e2fsck -v -f /dev/mapper/cachedev1
e2fsck 1.42.6 (21-Sep-2012)
The filesystem size (according to the superblock) is 986873856 blocks
The physical size of the device is 724834304 blocks
Either the superblock or the partition table is likely to be corrupt!
Several posts refer to TestDisk, but I did not find the find the courage to try it out (since there is some precious data on my RAID). Hence, before trying I thought I'd ask the experts whether TestDisk might be suitable for this problem.
I'd appreciate any help and suggestions you might have. Thanks a lot.
Re: Corrupt superblock or partition table
You can try to migrate back to Raid 1, copy your data, recreate the Raid, reformat and restore your files.
SirDakkon
#3 Post by SirDakkon »
Hello Christophe and thanks for your reply,
unfortunately I think I'm not able to just revert to the former state. The migration to RAID 5 was complete (at least according to the GUI and the mdadm output) but I do not have access to the volume due to corrupt superblock or partition table.
I tried to manually use alternative superblocks via "e2fsck -b". However, this did not work since e2fsck was not able to set the alternative superblock flag.
# e2fsck -b 644972544 /dev/mapper/cachedev1
DataVol1: recovering journal
e2fsck: unable to set superblock flags on DataVol1
DataVol1: ***** FILE SYSTEM WAS MODIFIED *****
DataVol1: ********** WARNING: Filesystem still has errors **********
Right now, I'm running PhotoRec to backup the data (should have done a proper backup way earlier). This will take some time (it's 3 TB of data). But it will also give me time to look for possible solutions :-) Of course, I'd appreciate any futher suggestions you might have.
