number of bytes per sector mismatches
azxcs
#1 Post by azxcs »
hi
i accidentally dropped my 3tb external hard disk when i'm transferring files, and it wont work
so i spent a couple days to do my research
and finally i came to this
all my files are fine(at least they all show up on the "list" option)
but everytime i try to copy them ,it disconnect
i tried to run the "rebuild bs" option
but im always stuck at 5963766
im really new to this and im not sure what to do next
can someone help me out :cry:
Re: number of bytes per sector mismatches
I've no idea about your OS!
Was your disk external and did you move it out of your enclosure to use it internally?
Which disk do you have?
azxcs
#3 Post by azxcs »
sorry for the late reply
i tried on both sata cable and usb hdd enclosure and they all works the same way
my os is win 8.1
also..it seems like the pics are not working so im gonna repost it here
http://imgur.com/pjTBQOw
http://imgur.com/XefpEC3
#4 Post by Fiona »
TestDisk 64bit is only intended on genuine 64bit machines like Itanium, which have no 32bit emulation like WoW64 (Windows on Windows) and there is a description that some features are missing.
Currently TestDisk 7.1WIP 32bit is recommended.
Can you repeat your diagnose and select Disk instead of PhysicallyDrive?
It looks like my disk selection here:
Currently your disk is recognized with 512 Bytes sector size and should be 4 K.
In case, under the menu "Geometry" sector size can be changed to 4096-
There is a description very dangerous.
But as long as you don't use Write, RepairMFT or BackupBS nothing will be changed and when you close TestDisk all settings will be lost.
Please run TestDisk / Analyse and Quick Search, to have a try to find your correct partition.
So, I'd be able to check your current partition structure (your partition table) and watch, is there another message about your sector size?
When a partition would be found, please select it and press p to have a try to list your data.
Can you copy and paste the content of your testdisk.log into your next post.
You'll find it within your testdisk folder and you can open it using wordpad.
azxcs
#5 Post by azxcs »
hi, thanks for the help
here the log before changing sector size
Wed Jan 20 18:57:16 2016
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249953443840
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2199023255040
Disk \\.\PhysicalDrive0 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive C: - 249 GB / 232 GiB - CHS 30388 255 63, sector size=512
Drive D: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive E: - 3000 GB / 2794 GiB - CHS 364784 255 63, sector size=512
Drive F: - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 364801 255 63
NTFS at 1/5/5
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)
Error: size boot_sector 732563456 > partition 4294967295
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 1 5 5 267350 94 7 4294967295
pread: Input/output error
Failed to calculate number of free clusters: Input/output error.
and here the log after changing sector size
NTFS at 1/5/5
NTFS at 1/5/5
filesystem size 732563456
sectors_per_cluster 1
mftmirr_lcn 2
clusters_per_mft_record 1
HPFS - NTFS 1 5 5 364800 190 62 5860507648 [Seagate Backup Plus Drive]
* HPFS - NTFS 1 5 5 364800 190 62 5860507648 [Seagate Backup Plus Drive]
file_win32_pread(144,16,buffer,6134280(381/214/34)) read err: read after end of file
file_win32_pread(144,1,buffer,6134280(381/214/34)) read err: read after end of file
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 1-Dec-2015 22:46 .
5 dr-xr-xr-x 0 0 0 1-Dec-2015 22:46 ..
9604 dr-xr-xr-x 0 0 0 21-Nov-2015 00:05 $RECYCLE.BIN
463960 dr-xr-xr-x 0 0 0 1-Dec-2015 21:59 BaiduYunDownload
128677 dr-xr-xr-x 0 0 0 20-May-2015 20:05 Games
128549 dr-xr-xr-x 0 0 0 2-Jul-2015 00:37 New folder
164466 dr-xr-xr-x 0 0 0 2-May-2015 12:22 New folder (4)
506075 dr-xr-xr-x 0 0 0 21-May-2015 18:14 Rainmeter
17998 dr-xr-xr-x 0 0 0 10-Mar-2015 17:41 SamsungRecovery
37 dr-xr-xr-x 0 0 0 19-Apr-2013 02:42 Seagate
96 dr-xr-xr-x 0 0 0 17-Jul-2015 20:35 System Volume Information
45 dr-xr-xr-x 0 0 0 19-Apr-2013 02:55 Video
158640 dr-xr-xr-x 0 0 0 1-Jun-2015 13:42 a
131049 dr-xr-xr-x 0 0 0 15-Mar-2015 22:23 anime
129379 dr-xr-xr-x 0 0 0 20-May-2015 20:05 anime h
525428 dr-xr-xr-x 0 0 0 1-Dec-2015 22:59 bt laptop 2015.12.1
290743 dr-xr-xr-x 0 0 0 1-Jun-2015 20:00 download
511415 dr-xr-xr-x 0 0 0 23-Nov-2015 02:27 downloads
292457 dr-xr-xr-x 0 0 0 30-May-2015 12:08 h
281090 dr-xr-xr-x 0 0 0 1-Jun-2015 14:09 music
482 dr-xr-xr-x 0 0 0 2-May-2015 00:01 動畫
4087 dr-xr-xr-x 0 0 0 2-May-2015 00:06 新增資料夾
1 * HPFS - NTFS 1 5 5 364800 190 62 5860507648 [Seagate Backup Plus Drive]
New geometry
Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 45601 255 63 sector_size=4096
Analyse Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 45601 255 63
#6 Post by Fiona »
Can you download and test the latest version of TesDisk 7.1WIP 32bit and test it?
http://www.cgsecurity.org/Download_and_ ... IP.win.zip
Your file system looks faulty.
Until yet, it's most important to backup/copy your files first.
Have another try to list your data and copy some files.
Can you test your copied files?
azxcs
#7 Post by azxcs »
it wont work
here is what i get
http://imgur.com/fWWRedp
