I'm trying to undelete some 16GB microSD card files. I received these messages during the process. Mac 10.7.5
Will I be able to recover these files?
Thanks!!!
Disk /dev/disk1 - 15 GB / 14 GiB - 30679040 sectors (RO)
Warning: number of heads/cylinder mismatches 4 (FAT) != 1 (HD)
Warning: number of sectors per track mismatches 16 (FAT) != 1 (HD)
1 * FAT32 LBA 2048 30679039 30676992 [NO NAME]
Warning: the current number of heads per cylinder is 1
but the correct value may be 128.
You can use the Geometry menu to change this value.
It's something to try if
- some partitions are not found by TestDisk
- or the partition table can not be written because partitions overlaps.
FAT32 LBA 2050 30679041 30676992 [NO NAME]
Invalid FAT boot sector
0 D FAT32 LBA 3203076717 5389803458 2186726742
Stop
The harddisk (15 GB / 14 GiB) seems too small! (< 2759 GB / 2570 GiB)
[ Continue ]
FAT32, blocksize=32768, 15 GB / 14 GiB
Help recovering deleted SD card files
Re: Help recovering deleted SD card files
Go in the Advanced menu to undelete your files
http://www.cgsecurity.org/wiki/TestDisk ... le_for_FAT
