TestDisk 7.0 no copy files more than 5GB
loiola2
#1 Post by loiola2 »
I've a file with 14GB in pendrive corrupted with partition RAW, when i try copy this file when this is with about 4.7GB the copy stop, but without error, and the file is incomplete.
The exact size of file is 4.761.240KB ever that try copy.
help me?
Thu Jan 28 11:30:52 2016
Re: TestDisk 7.0 no copy files more than 5GB
Can you
- post the section of the testdisk.log where there are information about the copied filed or the copy ?
- check if you have the same problem with PhotoRec 7.1-WIP for Windows 64 bits ?
Be careful to not store the recovered files on a FAT32.
loiola2
#3 Post by loiola2 »
cgrenier wrote:Can you
The problem occurs when i try recover the file without extension, the file name is EMPRESA.... When i use PhotoRec not list to recover, i believe it is because the file don't have extensions...
The destination partition is NTFS!
TESTDISK.LOG
Thu Jan 28 16:04:30 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=16000221184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=16000221184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=123028373504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=16000204800
filewin32_getfilesize(\\.\E:) GetFileSize err Função incorreta.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Função incorreta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\V:)=186542653440
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Disk /dev/sdb - 16 GB / 14 GiB - CHS 1945 255 63, sector size=512
Drive C: - 123 GB / 114 GiB - CHS 14957 255 63, sector size=512
Drive D: - 16 GB / 14 GiB - CHS 1945 255 63, sector size=512
Drive V: - 186 GB / 173 GiB - CHS 22679 255 63, sector size=512
NTFS at 0/0/33
1 P HPFS - NTFS 0 0 33 1945 63 38 31250400
NTFS, blocksize=4096, 16 GB / 14 GiB
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 22-Dec-2015 07:39 .
5 dr-xr-xr-x 0 0 0 22-Dec-2015 07:39 ..
52 dr-xr-xr-x 0 0 0 17-Apr-2015 10:29 DOCUMENTOS SCAN
36 dr-xr-xr-x 0 0 0 7-Dec-2015 17:31 System Volume Information
39 dr-xr-xr-x 0 0 0 26-Jan-2016 10:58 TrueCrypt
47 -r--r--r-- 0 0 15361638400 13-Mar-2014 12:55 EMPRESA
loiola2
#4 Post by loiola2 »
Any help?
#5 Post by cgrenier »
Can you boot from a Linux LiveCD/DVD and try the Linux version ?
The Linux version uses a more recent version of the ntfs library.
