PR7.0 keeps stucks always at the same region, no matter what
helt
#1 Post by helt »
I tried almost every possibility of options. Paranoid yes/no, bruteforce yes/no. But the result is always the same:
photorec makes good progress until sector 529.something, then it appears to keep looping over and over again over the same sectors. As you can see, the current sector sometimes even decreases.
However, this is just 25% of the whole volume-set. And i am really passionate to somehow get the other 75% recovered, too. I am trying to recover the data for more than one month now, but never got past the 25%.
Any ideas anyone?
Pass 1 - Reading sector 5329646616/19515727872, 602579 files found
Elapsed time 167h57m54s - Estimated time to completion 447h04m39
Pass 1 - Reading sector 5330459312/19515727872, 602603 files found
Elapsed time 167h58m37s - Estimated time to completion 447h00m55
Pass 1 - Reading sector 5329765944/19515727872, 632569 files found
Elapsed time 182h36m27s - Estimated time to completion 486h02m12
Pass 1 - Reading sector 5330300208/19515727872, 632571 files found
Elapsed time 182h36m31s - Estimated time to completion 485h58m22
Pass 1 - Reading sector 5330835376/19515727872, 632573 files found
Elapsed time 182h36m35s - Estimated time to completion 485h54m31
Re: PR7.0 keeps stucks always at the same region, no matter
Please try PhotoRec 7.1-WIP. Copy the photorec.ses file from 7.0, start PhotoRec 7.1-WIP and choose to continue the previous session.
helt
#3 Post by helt »
is there a static binary avaliable? I am running PR on a NAS and have not really a clue about compiling Linux source code.
Linux DiskStation 3.10.35 #5644 SMP Fri Jan 22 13:38:47 CST 2016 x86_64 GNU/Linux synology_cedarview_412+
helt
#4 Post by helt »
ok. the static from the 7.1-WIP does start. If it starts, the rest will work as expected, too, right?
helt
#5 Post by helt »
ok. seems to work now.
Pass 1 - Reading sector 5529628568/19515727872, 521217 files found
Elapsed time 0h39m12s - Estimated time to completion 1h39m08
jpg: 520640 recovered
Out of curiosity: Do you know whats the cause for this? Is it some border case problem, or is this "normal" for big volumes?
best, and many thanks,
Helt
#6 Post by cgrenier »
The problem has probably been fixed by this commit https://git.cgsecurity.org/cgit/testdis ... a4a0e4fdfd
