i use "mini windows XP" from Hiren's boot CD
Photorec_win.exe (ver 6.14) in it works very well
But, photorec_win.exe which i downloaded doesnt start(launch) - i see black window for 1,5 second only.
qphotorec_win.exe (ver 7.0) works for me but it have not so much options as photorec without GUI.
winXP, photorec_win.exe does not start (ver.7)
Re: winXP, photorec_win.exe does not start (ver.7)
It may be better to check the problem with Hiren himself.
Can you try version 7.1-WIP, start it in command line (cmd) so you get see any error message ?
i see no errorsget see any error message ?
I launched photorec_win and testdisk_win (ver 7.1 WIP)from command prompt
and them doesnt show anything - after 1.5 seconds them bring me command line back
may be anything changed around cygwin after ver 6.14-WIP?
But QT - GUI version works very well.
