recovering a Windows 2003 RAID 5 volume accidently deleted
Gagou
#1 Post by Gagou »
Sometimes we are tired and are not really reading messages which are in front of us. :(
On windows 2003
I had a failed drive on a raid 5 volume ( created by windows ==> software RAID)
I replaced it with a bigger disk
but after having add it to the RAID 5 volume, I changed my mind and wanted to configure the partitions on this new bigger disk differently and to do that I have :oops: stupidly incidently destroyed the volume on each of the raid 5 disks.
What can I do now ? I just see with the disk manager non-allocated space at the place of my RAID 5 volume .
Is there a solution for this stupidity :oops: ?
Please Help me !
Re: recovering a Windows 2003 RAID 5 volume accidently delet
Try TestDisk, Analyse, Quick Search on each disk to search for the missing partition.
Please post the testdisk.log file content.
Gagou
#3 Post by Gagou »
Hi Christophe
First of all, thank you for your help
I have done what you asked
I put the log on my dropbox here https://www.dropbox.com/s/x627ip9h8tsic ... k.log?dl=0
but to help on the results, I also put pictures of the config in the disk manager Originally this structure was done with three 500GB disks (disk 0,1,2)
As you can see the two first disks have 3 partitions, the 2 first partitions are actually operational to form a dual-boot and both OS are in mirror RAID.They are working without any problems
The last partitions on disk 0 and 1 and the fist partition on disk 2 created a volume named RAID-5_700 of ...700GiB which is the one I destroyed.
Disk 2 died, I replaced it by a bigger 1 terabyte disk. I rebuilt the volume RAID-5_700 and .... I suppressed the volume by error by acting on the new disk 2
By the way I have seen that you are french, so am I. As so I can continue in any languages of your preference. I guess english should be better on this international forum.
On the log, you probably will see that I scanned the disk 2 twice, which was also ...an error
Thank you again for your time
Gagou
#4 Post by Gagou »
Hello Christophe
Have you downloaded the .log file from my dropbox above
I'm a newbie on this domain but opened with notepad++ on lines 174-203 we have
NTFS at 0/1/1
filesystem size 32772537
mftmirr_lcn 2048283
HPFS - NTFS 0 1 1 2039 254 63 32772537
NTFS, blocksize=4096, 16 GB / 15 GiB
NTFS at 2040/0/1
filesystem size 209712510
mftmirr_lcn 13107031
HPFS - NTFS 2040 0 1 15093 254 63 209712510
NTFS, blocksize=4096, 107 GB / 99 GiB
NTFS at 15094/0/1
filesystem size 1468563456
mftmirr_lcn 91785215
HPFS - NTFS 15094 0 1 106507 216 3 1468563456
NTFS, blocksize=4096, 751 GB / 700 GiB
This partition ends after the disk limits. (start=242485110, size=1468563456, end=1711048565, disk end=976773168)
On lines 233-238
The harddisk (500 GB / 465 GiB) seems too small! (< 876 GB / 815 GiB)
Here TestDisk to find 876GB clearly added in its calculation
16000 MB (1st partition named XPProMaster 15.63 GiB)
+ 102400 MB (2d partition named W2K3Master 100.00 GiB)
+ 751 GB ( the destroyed volume named RAID-5_700 of of 700GiB)
= 876 GB (total = 815 GiB)
on line 281 we can see:
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 1938021 16 63
NTFS at 0/1/1
heads/cylinder 255 (NTFS) != 16 (HD)
HPFS - NTFS 0 1 1 1456908 4 3 1468563456
I guess this are souvenirs from my 700Gib raid 5 volume
I 'm surprised at the fact there is a fat12 partition on sda ? does testDisk is looking for diskets too ?
and no vision of the raid partition on sda, quick scan I guess
So what can I do now ?
