I started up my machine this morning to discover that one of my partitions wasn't available to view by disk letter. Using the Disk Management console I tried to give it a letter and I'm given the error that the view isn't up-to-date and I need to refresh disk management. No matter how many times I refresh I cannot do anything with the disk, I can't even see the properties.
Using TestDisk I'm able to successfully see the missing partition and all the files on it. I've copied all my files from the missing partition but would much rather repair the partition rather than having to start again!
When viewing the partition structure in TestDisk I get this:
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
1 * HPFS - NTFS 0 32 33 828 194 6 13312000 [Recovery]
2 P HPFS - NTFS 828 194 7 867 1 30 614400 [System]
3 P HPFS - NTFS 867 1 31 13928 112 8 209831936 [Windows7]
4 E extended LBA 13928 112 9 60801 80 15 753012736
5 L HPFS - NTFS 13928 144 41 60801 254 63 753021698 [Data]
P HPFS - NTFS 1867 1 31 13928 112 8 209831936 [Windows7]
L HPFS - NTFS 13928 144 41 60801 47 46 753008640 [Data]
Can I just delete P4 out of the partition table?! Will that cause it all to right itself?
Any help that can be given will be much appreciated.
