Adobe has changed Premiere Pro files ("*.prproj") from txt/xml files to gzip in 2013. Photorec recovers old pproj files as tx? without problem, but has issues with newer pproj files if recovered as "tx?".
Is there a way to treat prproj files as gzip?
Let me know if you need samples,
Thank you -
kind regards
Juergen
.prproj files now gzip
Re: .prproj files now gzip
Hello, everybody,
I eventually solved the issue posted above so here's the solution in case someone else has it later:
Adobe Premiere files above version CS6.5 can be recovered with photorec gz file family. They will be found as "*.xml.gz" but indeed they are ".prproj" files, just change the extension.
Some files may be damaged. A good procedure to filter any damaged file is to extract the archives in a fresh folder. Any file that cannot be extracted is not prproj, or is damaged.
You may find quite a lot of project files. To filter the project you are looking for, run a text content search with your original project name over all extracted files. Some files may still contain a lot of garbage that you can easily identify and erase with a text editor. Maybe fix xml structure. Re-gzip, open in Premiere. Worked for me!
Merci Monsieur Grenier!
Juebi
Juebi
Who is online
Users browsing this forum: No registered users and 0 guests
