No Partition Found
bookwurm99
Re: No Partition Found
#11 Post by bookwurm99 »
Mon Aug 15 14:10:43 2016
TestDisk 7.1-WIP, Data Recovery Utility, April 2016
Compilation date: 2016-08-10T09:23:23
ext2fs lib: 1.42.8, ntfs lib: 10:0:0, reiserfs lib: 0.3.1-rc8, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=64034439168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=64034439168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=225050624000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=750054801408
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=64034439168
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 840 EVO 250GB mSATA, S/N:3153504b534e4641303734313330205720202020, FW:EXT43B6Q
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - WDC WD7500BPKX-60HPJT0, S/N:2020202057202d445857314d3145533441543957, FW:01.01A01
Disk /dev/sdc - 64 GB / 59 GiB - CHS 7785 255 63, sector size=512 - O2Micro SD, FW:0001
Disk /dev/sdc - 64 GB / 59 GiB - O2Micro SD
Analyse Disk /dev/sdc - 64 GB / 59 GiB - CHS 7785 255 63
file_pread(6,1,buffer,125067265(7785/19/44)) lseek err Invalid argument
file_pread(6,2,buffer,125068072(7785/32/32)) lseek err Invalid argument
file_pread(6,1,buffer,125068072(7785/32/32)) lseek err Invalid argument
file_pread(6,2,buffer,125068073(7785/32/33)) lseek err Invalid argument
file_pread(6,2,buffer,125068136(7785/33/33)) lseek err Invalid argument
file_pread(6,1,buffer,125068136(7785/33/33)) lseek err Invalid argument
file_pread(6,14,buffer,125067266(7785/19/45)) lseek err Invalid argument
file_pread(6,3,buffer,125067280(7785/19/59)) lseek err Invalid argument
file_pread(6,3,buffer,125067327(7785/20/43)) lseek err Invalid argument
file_pread(6,8,buffer,125067343(7785/20/59)) lseek err Invalid argument
file_pread(6,11,buffer,125067390(7785/21/43)) lseek err Invalid argument
file_pread(6,2,buffer,125069312(7785/52/12)) lseek err Invalid argument
Store new MBR code
file_pread(6,1,buffer,125067264(7785/19/43)) ReadFile The request could not be performed because of an I/O device error.
AndyMaxwell
#12 Post by AndyMaxwell »
Hi cgrenier , it's taken me a while to get back to you, the disk is still working but the errors are still present. As requested please find my 7.1 log below. Thank you.
*Please note that I have removed many many entries from the sectors list to save characters, happy to provide if needed*
Thu Oct 27 20:28:30 2016
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=240054697984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202241024
Disk \\.\PhysicalDrive0 - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - SanDisk SDSSDXP240G, S/N:3431353237313034343039342020202020202020, FW:R1311
Disk \\.\PhysicalDrive1 - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - KINGSTON SV300S37A120G, S/N:3035323042363337313333303844354420202020, FW:505ABBF0
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Freecom , S/N:F1983G94AA7Y18, FW:1302
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - Freecom
FAT32 at 0/1/1
test_FAT size boot_sector 1953520065 > partition 1953520002
test_FAT()
 1 * FAT32                    0   1  1 121600 254 63 1953520002
sector_size  512
cluster_size 64
reserved     32
fats         2
dir_entries  0
sectors      0
media        F8
fat_length   0
secs_track   63
heads        255
hidden       63
total_sect   1953520065
fat32_boot_sector
FAT32 at 0/1/1
FAT32 at 0/1/1
Error: size boot_sector 1953520065 > partition 1953520002
Bad
Bad
Sectors are identical.
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=6873331, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
FAT32 at 32(0/1/33), nbr=93804
FAT32 at 101558(6/83/3), nbr=1
FAT32 at 101559(6/83/4), nbr=1
FAT32 at 113208(7/12/61), nbr=1
FAT32 at 113710(7/20/59), nbr=1
FAT32 at 124595(7/193/45), nbr=1
FAT32 at 238259(14/212/57), nbr=1
FAT32 at 238470(14/216/16), nbr=93804
FAT32 at 339996(21/42/49), nbr=1
FAT32 at 339997(21/42/50), nbr=1
FAT32 at 351646(21/227/44), nbr=1
FAT32 at 352148(21/235/42), nbr=1
FAT32 at 363033(22/153/28), nbr=1
FAT32 at 476697(29/172/40), nbr=1
********MANY MANY ENTRIES REMOVED FROM HERE TO REDUCE LENGTH OF POST!*******
FAT32 at 526085(32/191/36), nbr=1
FAT32 at 526086(32/191/37), nbr=1
FAT32 at 6246480(388/211/31), nbr=1
FAT32 at 4036540(251/68/5), nbr=2
first_fat 32, second_fat 238470
FAT : 32, reserved=32, fat_length=238438
sectors_per_cluster 64
next_free 9457, free_count 18564449
fat32_find_root_cluster(sectors_per_cluster=64,no_of_cluster=30516298,reserved=32,fat_length=238438,expert=0,first_free_cluster=9457)
cluster 2, etat=0, found=1,nb_subdir=11,nb_subdir_ok=11
prev cluster(2)=>0
             New / Current boot sector
FAT32
sector_size  512 512
cluster_size 64 64
reserved     32 32
fats         2 2
dir_entries  0 0
sectors      0 0
media        F8 F8
fat_length   0 0
secs_track   63 63
heads        255 255
hidden       63 63
total_sect   1953520002 1953520065
fat32_length 238438 238438
flags        0000 0000
version      0.0  0.0
root_cluster 2 2
info_sector  1 1
backup_boot  6 6
free_count   uninitialised 18564450
next_free    uninitialised 14675
dir_partition inode=0
FAT: cluster=2(0x2), pos=476971
       3 -rwxr-xr-x     0      0      8196 25-Jun-2012 17:18 .DS_Store
       4 -rwxr-xr-x     0      0     99198 16-Jun-2011 14:00 .VolumeIcon.icns
       8 -rwxr-xr-x     0      0        82 24-Nov-2010 12:50 ._autorun.inf
       9 -rwxr-xr-x     0      0        82 24-Nov-2010 12:50 ._icon.ico
      10 -rwxr-xr-x     0      0      4096  8-Nov-2011 12:49 .__
      11 -rwxr-xr-x     0      0        49 23-Oct-2012 10:29 AUTORUN.INF
      12 -rwxr-xr-x     0      0     38930 16-Jun-2011 13:52 ICON.ICO
 14159110 -rwxr-xr-x     0      0    904704  1-Dec-2006 22:37 MSDIA80.DLL
X    658 drwxr-xr-x     0      0     32768 26-Oct-2016 19:58 MSIb8f56.tmp
X    957 drwxr-xr-x     0      0     32768 14-Aug-2016 17:48 MSI3fc1d.tmp
X      2 -rwxr-xr-x     0      0     56958  7-Aug-2016 21:17 _63S.S
X  38842 drwxr-xr-x     0      0     32768 31-Jul-2016 18:17 _SIB76F2.TMP
X  16093 drwxr-xr-x     0      0     32768 31-Jul-2016 14:17 _1C32A~1
X  16093 drwxr-xr-x     0      0     32768 31-Jul-2016 14:17 _DA7AC~1
    9620 drwxr-xr-x     0      0         0 20-Jun-2015 16:41 $RECYCLE.BIN
X  16483 drwxr-xr-x     0      0     32768 31-Jul-2016 14:17 MSIc4d59.tmp
X   9622 drwxr-xr-x     0      0     32768 20-Jun-2015 16:50 Programs to Keep
X   7207 drwxr-xr-x     0      0     32768 24-Jun-2015 20:20 MSIb4cea.tmp
X   7207 drwxr-xr-x     0      0     32768 24-Jun-2015 20:21 MSIb4cfa.tmp
X   7207 drwxr-xr-x     0      0     32768 24-Jun-2015 20:21 MSIb4d05.tmp
X   7207 drwxr-xr-x     0      0     32768 24-Jun-2015 20:21 MSIb4dc6.tmp
X   7207 drwxr-xr-x     0      0     32768 24-Jun-2015 20:21 MSIb4e1a.tmp
X   7207 drwxr-xr-x     0      0     32768 24-Jun-2015 20:22 MSIb4e22.tmp
X   7207 drwxr-xr-x     0      0     32768 24-Jun-2015 20:22 MSIb4e27.tmp
X   9452 drwxr-xr-x     0      0         0 28-Jun-2015 08:32 Freecom Files
X   9453 drwxr-xr-x     0      0         0 28-Jun-2015 08:43 New folder
X   9453 drwxr-xr-x     0      0         0 28-Jun-2015 08:43 Movies - Freecom
X   9454 drwxr-xr-x     0      0         0 28-Jun-2015 08:43 New folder
X   9454 drwxr-xr-x     0      0         0 28-Jun-2015 08:43 Music - Freecom
X   9455 drwxr-xr-x     0      0         0 28-Jun-2015 08:44 New folder
X   9455 drwxr-xr-x     0      0         0 28-Jun-2015 08:44 Pictures - Freecom
X   9456 drwxr-xr-x     0      0         0 28-Jun-2015 08:44 TV- Freecom
    9452 drwxr-xr-x     0      0         0 28-Jun-2015 08:32 Freecoms Files
X   9457 drwxr-xr-x     0      0         0 23-Apr-2011 09:04 Audiobooks
   21941 drwxr-xr-x     0      0         0 23-Mar-2012 09:29 Everything else
  128718 drwxr-xr-x     0      0         0  7-Mar-2011 21:17 Movies
 1049760 drwxr-xr-x     0      0         0  8-Jul-2011 14:30 Music
X3425018 drwxr-xr-x     0      0         0 29-Jun-2014 14:37 Podcasts
 3430039 drwxr-xr-x     0      0         0 20-Mar-2012 17:50 TV
 4894325 dr-xr-xr-x     0      0         0 20-Apr-2015 20:01 GoPro Vids
X5235780 drwxr-xr-x     0      0         0 14-Jun-2015 08:50 Movies 2
X6789803 drwxr-xr-x     0      0         0 23-Mar-2015 22:05 Music 2
 6989832 drwxr-xr-x     0      0         0 20-Jun-2015 16:16 Pictures
X7759347 drwxr-xr-x     0      0         0 20-Jun-2015 17:13 TV 2
X  61616 drwxr-xr-x     0      0     32768 15-Jul-2015 19:11 MSI462da.tmp
X  61616 drwxr-xr-x     0      0     32768 15-Jul-2015 19:11 MSI462dd.tmp
X  61616 drwxr-xr-x     0      0     32768 15-Jul-2015 20:04 MSI519cb.tmp
X  61616 drwxr-xr-x     0      0     32768 15-Jul-2015 20:04 MSI519cf.tmp
X      2 drwxr-xr-x     0      0     32768 16-Jul-2015 18:50 MSIac9f5.tmp
X      2 drwxr-xr-x     0      0     32768 16-Jul-2015 18:51 MSIac9fb.tmp
X      2 drwxr-xr-x     0      0     32768 16-Jul-2015 19:00 MSI640d9.tmp
X      2 drwxr-xr-x     0      0     32768 16-Jul-2015 19:19 MSI7a547.tmp
X      2 drwxr-xr-x     0      0     32768 20-Jul-2015 20:10 _146812_
X      2 drwxr-xr-x     0      0     32768 20-Jul-2015 20:10 152b00163bea961237d9d090f1c6
X    189 drwxr-xr-x     0      0     32768 20-Jul-2015 20:10 _SI24847.TMP
X      2 drwxr-xr-x     0      0     32768 22-Jul-2015 09:07 MSIf9acb.tmp
X      2 drwxr-xr-x     0      0     32768 22-Jul-2015 09:07 MSIf9adb.tmp
X      2 drwxr-xr-x     0      0     32768 22-Jul-2015 09:07 MSIf9ae4.tmp
X      2 drwxr-xr-x     0      0     32768 22-Jul-2015 09:08 MSIf9ba4.tmp
X      2 drwxr-xr-x     0      0     32768 22-Jul-2015 09:08 MSIf9bf6.tmp
X      4 drwxr-xr-x     0      0     32768 24-Aug-2015 19:34 MSIbdedc.tmp
X      4 drwxr-xr-x     0      0     32768 24-Aug-2015 19:34 MSIbdf9b.tmp
X      4 drwxr-xr-x     0      0     32768 24-Aug-2015 19:34 MSIbdfec.tmp
X      4 drwxr-xr-x     0      0     32768 24-Aug-2015 19:35 MSIbdff2.tmp
X      4 drwxr-xr-x     0      0     32768 24-Aug-2015 19:35 MSIbdffc.tmp
X8128286 drwxr-xr-x     0      0         0 26-Aug-2015 20:39 Mazda
 8127822 drwxr-xr-x     0      0         0 21-Jun-2015 10:00 Programs to Keep
X8192682 drwxr-xr-x     0      0         0 28-Jun-2015 07:49 Nice rooms
 8192859 dr-xr-xr-x     0      0         0 31-Aug-2015 13:34 ANDREWS-PC
 7629145 -r-xr-xr-x     0      0       528 31-Aug-2015 13:34 MediaID.bin
X  16545 drwxr-xr-x     0      0     32768 31-Aug-2015 14:26 MSIb324c.tmp
X  28901 drwxr-xr-x     0      0     32768 31-Aug-2015 21:50 9773ea61-1c06-4a75-a441-a3cb686c0800
X  28901 drwxr-xr-x     0      0     32768 31-Aug-2015 21:50 8d05bf33d9eea8d36bfb1a7acb75
X      2 drwxr-xr-x     0      0     32768  9-Sep-2015 19:28 _786822_
X      2 drwxr-xr-x     0      0     32768  9-Sep-2015 19:28 1704ae03e17c726ebb80776f50747e6c
X      2 drwxr-xr-x     0      0     32768 15-Sep-2015 22:48 MSIbda6.tmp
X      2 drwxr-xr-x     0      0     32768 15-Sep-2015 22:49 MSIbdb0.tmp
X      2 drwxr-xr-x     0      0     32768 15-Sep-2015 22:49 MSIbe6f.tmp
X      2 drwxr-xr-x     0      0     32768 15-Sep-2015 22:49 MSIbec1.tmp
X      2 drwxr-xr-x     0      0     32768 15-Sep-2015 22:49 MSIbec9.tmp
X      2 drwxr-xr-x     0      0     32768 21-Sep-2015 18:33 MSI6af75.tmp
X      2 drwxr-xr-x     0      0     32768 24-Sep-2015 08:33 _137858_
X      2 drwxr-xr-x     0      0     32768 24-Sep-2015 08:33 3cfd512c1ecece1e3317a1e354
X      2 drwxr-xr-x     0      0     32768 24-Sep-2015 08:33 _149090_
X      2 drwxr-xr-x     0      0     32768 24-Sep-2015 08:33 d8f75b63d0daa423c8
X      2 drwxr-xr-x     0      0     32768 25-Sep-2015 19:28 MSIbda89.tmp
X      2 drwxr-xr-x     0      0     32768 25-Sep-2015 19:28 MSIbda93.tmp
X      2 drwxr-xr-x     0      0     32768 25-Sep-2015 19:28 MSIbda9c.tmp
X      2 drwxr-xr-x     0      0     32768 25-Sep-2015 19:28 MSIbdb5b.tmp
X      2 drwxr-xr-x     0      0     32768 25-Sep-2015 19:28 MSIbdbac.tmp
X    813 drwxr-xr-x     0      0     32768 27-Sep-2015 09:40 _660882_
X    813 drwxr-xr-x     0      0     32768 27-Sep-2015 09:40 36a0fe0f70d3e98f55d357b7131d55
X    813 drwxr-xr-x     0      0     32768 27-Sep-2015 09:40 _664470_
X9569069 drwxr-xr-x     0      0         0 27-Sep-2015 09:40 _EMP
X   7055 drwxr-xr-x     0      0     32768  2-Oct-2015 23:14 _646936_
X   7055 drwxr-xr-x     0      0     32768  2-Oct-2015 23:14 e09f86c63c6941ec57
X   5939 drwxr-xr-x     0      0     32768 13-Oct-2015 20:37 MSIc321b.tmp
X   5939 drwxr-xr-x     0      0     32768 13-Oct-2015 20:38 MSIc321f.tmp
X   5939 drwxr-xr-x     0      0     32768 14-Oct-2015 20:57 _645641_
X   5939 drwxr-xr-x     0      0     32768 14-Oct-2015 20:57 a741e133b9d6b81299760b5494f8a7a8
X      2 drwxr-xr-x     0      0     32768 16-Oct-2015 19:07 _134644_
X      2 drwxr-xr-x     0      0     32768 16-Oct-2015 19:07 862dd0d825626c39b7e8bc610285b0
X      3 drwxr-xr-x     0      0     32768 17-Oct-2015 13:13 MSIe27fd.tmp
X   4550 drwxr-xr-x     0      0     32768 18-Oct-2015 18:37 _041262_
X   4550 drwxr-xr-x     0      0     32768 18-Oct-2015 18:37 e4c55f946e5eb5e233a3d0be3d
X   4551 drwxr-xr-x     0      0     32768 19-Oct-2015 18:39 _635282_
X   4551 drwxr-xr-x     0      0     32768 19-Oct-2015 18:39 334e7f8c086be39a4ce7150f
X      2 drwxr-xr-x     0      0     32768 20-Oct-2015 23:08 _702909_
X      2 drwxr-xr-x     0      0     32768 20-Oct-2015 23:08 7179514f7f6dcea39a9a
X   3807 drwxr-xr-x     0      0     32768 22-Oct-2015 17:42 _134535_
X   3807 drwxr-xr-x     0      0     32768 22-Oct-2015 17:42 e43fba872cc015c453c4a6973c
X   3807 drwxr-xr-x     0      0     32768 24-Oct-2015 08:56 _035755_
X   3807 drwxr-xr-x     0      0     32768 24-Oct-2015 08:56 9880050cfbd631a869
X   3837 drwxr-xr-x     0      0     32768 25-Oct-2015 13:13 _634612_
X   3837 drwxr-xr-x     0      0     32768 25-Oct-2015 13:13 e9650eb5c5bd7d3c0144
X   3837 drwxr-xr-x     0      0     32768 26-Oct-2015 20:07 _696794_
X   3837 drwxr-xr-x     0      0     32768 26-Oct-2015 20:07 0e5d1c80affcca0bbb7fb6e9432a59
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 11:59 _635048_
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 11:59 bcfb3fc3cae301c980d5e90bff
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 11:59 _648028_
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 11:59 d37fb96ea7ca80f4395d4f46
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 12:08 _SI14904.TMP
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 12:08 _SI14914.TMP
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 12:08 MSI1491d.tmp
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 12:08 MSI149dc.tmp
X   2858 drwxr-xr-x     0      0     32768 28-Oct-2015 12:08 MSI14a2d.tmp
X   9944 drwxr-xr-x     0      0     32768 29-Oct-2015 17:51 _642334_
X   9944 drwxr-xr-x     0      0     32768 29-Oct-2015 17:51 167b30ae68ff609e27204c5f633366
X   3807 drwxr-xr-x     0      0     32768 30-Oct-2015 22:28 _698650_
X   3807 drwxr-xr-x     0      0     32768 30-Oct-2015 22:28 1e8d2ba0a018dde3b211314df01790
X   6097 drwxr-xr-x     0      0     32768  1-Nov-2015 14:53 _633410_
X   6097 drwxr-xr-x     0      0     32768  1-Nov-2015 14:53 054f7ec5bec905290038863e00cb
X      2 drwxr-xr-x     0      0     32768  3-Nov-2015 13:54 _043680_
X      2 drwxr-xr-x     0      0     32768  3-Nov-2015 13:54 1258bc78f7194d9c8eaebd
X      2 drwxr-xr-x     0      0     32768  4-Nov-2015 21:10 _037190_
X      2 drwxr-xr-x     0      0     32768  4-Nov-2015 21:10 11ffe66d4cfe7b5d50a1
X   2800 drwxr-xr-x     0      0     32768  7-Nov-2015 10:19 _088577_
X   2800 drwxr-xr-x     0      0     32768  7-Nov-2015 10:19 217a057151f51ee1f12e
X      2 drwxr-xr-x     0      0     32768  8-Nov-2015 12:08 _697839_
X      2 drwxr-xr-x     0      0     32768  8-Nov-2015 12:09 3ae37d93427c9bc6d0ff8d
X  41789 drwxr-xr-x     0      0     32768  8-Nov-2015 18:30 MSI2235a.tmp
X  41789 drwxr-xr-x     0      0     32768  8-Nov-2015 18:30 _SI22367.TMP
X      2 drwxr-xr-x     0      0     32768  9-Nov-2015 18:36 _714749_
X      2 drwxr-xr-x     0      0     32768  9-Nov-2015 18:36 b9e84920acaa423ae58f
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:41 MSI935b.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:42 MSI11c4a.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:42 MSI935e.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:42 MSI11c4f.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:43 MSI11c56.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11c5e.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11d99.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11d9e.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11da5.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11dbe.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11dc3.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11dc8.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11dcd.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11dd2.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11dd7.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11ddc.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11de1.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11de6.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11deb.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11df0.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11df5.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11dfa.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11dff.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e04.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e09.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e0e.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e13.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e18.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e1d.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e22.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e27.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e2c.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e31.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e36.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e3d.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e49.tmp
X      3 drwxr-xr-x     0      0     32768  9-Nov-2015 19:44 MSI11e6f.tmp
X      3 drwxr-xr-x     0      0     32768 10-Nov-2015 18:42 _055442_
X      3 drwxr-xr-x     0      0     32768 10-Nov-2015 18:42 644b47b27f4d575d8878f9b1c7
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:09 _SI94211.TMP
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:09 _SI94214.TMP
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa41b3.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa41bb.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa42e7.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa42ec.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa42f2.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa430b.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4310.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4315.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa431a.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa431f.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4324.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4329.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa432e.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4333.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4338.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa433d.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4342.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4347.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa434c.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4351.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4356.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa435b.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4360.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4365.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa436a.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa436f.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4374.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4379.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa437e.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4383.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa438a.tmp
X  37541 drwxr-xr-x     0      0     32768 10-Nov-2015 19:10 MSIa4396.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 _SI38622.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 _SI38629.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 _SI38630.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 _SI38637.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 MSI3863e.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 MSI3866c.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 _SI38672.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 MSI3867a.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:15 _SI38681.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38688.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38690.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38697.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI3869e.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386a5.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386ac.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386b3.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386ba.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386c1.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386c8.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386cf.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386d6.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386dd.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386e4.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386eb.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386f2.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI386f9.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38700.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38707.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI3870e.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38715.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI3871c.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38723.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI3872a.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38731.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38738.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI3873f.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38747.TMP
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 MSI3874d.tmp
X      2 drwxr-xr-x     0      0     32768 10-Nov-2015 19:16 _SI38773.TMP
X      2 drwxr-xr-x     0      0     32768 11-Nov-2015 21:32 _709476_
X      2 drwxr-xr-x     0      0     32768 11-Nov-2015 21:32 93c988769d84b6ad0a7ac0ed
X      3 drwxr-xr-x     0      0     32768 14-Nov-2015 06:33 _090152_
X      3 drwxr-xr-x     0      0     32768 14-Nov-2015 06:33 4464b08900fb00efd7ed8f5202
X      3 drwxr-xr-x     0      0     32768 16-Nov-2015 18:01 _042167_
X      3 drwxr-xr-x     0      0     32768 16-Nov-2015 18:01 8e2b8a2363a034db3b2232a67844e6
X   2761 drwxr-xr-x     0      0     32768 18-Nov-2015 18:10 _041792_
X   2761 drwxr-xr-x     0      0     32768 18-Nov-2015 18:10 e11a344b5ff03db34503
X   2762 drwxr-xr-x     0      0     32768 19-Nov-2015 19:21 _644814_
X   2762 drwxr-xr-x     0      0     32768 19-Nov-2015 19:21 c2196329b3aafc8707bb1f
X   2762 drwxr-xr-x     0      0     32768 20-Nov-2015 19:34 _623395_
X   2762 drwxr-xr-x     0      0     32768 20-Nov-2015 19:34 95e9c9ea09126383aaf7d243868a
X   2762 drwxr-xr-x     0      0     32768 22-Nov-2015 17:47 _149152_
X   2762 drwxr-xr-x     0      0     32768 22-Nov-2015 17:47 0f45e590ede4f9913e3fe37a44e4cd7e
X   2766 drwxr-xr-x     0      0     32768 23-Nov-2015 18:00 _636140_
X   2766 drwxr-xr-x     0      0     32768 23-Nov-2015 18:00 5d80ee60cba28538b45276294207
X   2766 drwxr-xr-x     0      0     32768 24-Nov-2015 21:34 _713501_
X   2766 drwxr-xr-x     0      0     32768 24-Nov-2015 21:34 7b06998488932f5174de563f
X   2766 drwxr-xr-x     0      0     32768 24-Nov-2015 21:35 MSIbd6e1.tmp
X   2766 drwxr-xr-x     0      0     32768 24-Nov-2015 21:36 MSIbd6ef.tmp
X   2766 drwxr-xr-x     0      0     32768 24-Nov-2015 21:36 MSIbd6f8.tmp
X   2766 drwxr-xr-x     0      0     32768 24-Nov-2015 21:36 MSIbd7b7.tmp
X   2766 drwxr-xr-x     0      0     32768 24-Nov-2015 21:36 MSIbd808.tmp
X  27056 drwxr-xr-x     0      0     32768 26-Nov-2015 08:07 _640368_
X  27056 drwxr-xr-x     0      0     32768 26-Nov-2015 08:07 8617fe51ff2fc87df66e7660dc0e32
X   5940 drwxr-xr-x     0      0     32768 27-Nov-2015 20:10 _703845_
X   5940 drwxr-xr-x     0      0     32768 27-Nov-2015 20:10 e1f2468d286bd8cbea33
X   5941 drwxr-xr-x     0      0     32768 30-Nov-2015 15:46 _041808_
X   5941 drwxr-xr-x     0      0     32768 30-Nov-2015 15:46 b4d890d694cd24769afe19d6be
X   5943 drwxr-xr-x     0      0     32768  1-Dec-2015 21:45 _704968_
X   5943 drwxr-xr-x     0      0     32768  1-Dec-2015 21:45 7213c34e5db48a45cc8f62
X   6103 drwxr-xr-x     0      0     32768  2-Dec-2015 23:08 _643987_
X   6103 drwxr-xr-x     0      0     32768  2-Dec-2015 23:08 748c9f1e7e9a84daaedb422b11
X   2776 drwxr-xr-x     0      0     32768  4-Dec-2015 17:34 _039109_
X   2776 drwxr-xr-x     0      0     32768  4-Dec-2015 17:34 fb31404df870e2996a55765a
X   2776 drwxr-xr-x     0      0     32768  4-Dec-2015 19:40 MSIbda5b.tmp
X  11109 drwxr-xr-x     0      0     32768  6-Dec-2015 10:58 _145299_
X  11109 drwxr-xr-x     0      0     32768  6-Dec-2015 10:58 1232b71908ade181a3cdfb
X  11109 drwxr-xr-x     0      0     32768  6-Dec-2015 12:08 _SI26848.TMP
X  11109 drwxr-xr-x     0      0     32768  6-Dec-2015 12:08 MSI2684f.tmp
X  11109 drwxr-xr-x     0      0     32768  6-Dec-2015 12:09 MSI2686b.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 17:02 _165215_
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 17:02 f2bd6073bdf5437b1f30db
X  12483 drwxr-xr-x     0      0     32768  6-Dec-2015 17:02 _168679_
X  12483 drwxr-xr-x     0      0     32768  6-Dec-2015 17:02 31c96554c2ad68f900b0
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:20 58c18fda-7166-404d-8136-91c8b8aa7f88
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:20 5caef94199f171b76ce090468b
X  12559 drwxr-xr-x     0      0     32768  6-Dec-2015 18:20 MSIeeb22.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:24 a665d720-4234-41c5-baef-9261f9dc9909
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:24 8db6c4f13b4ce063984ae63a0283
X  12770 drwxr-xr-x     0      0     32768  6-Dec-2015 18:24 MSI220e1.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:26 f6f2e25a-4248-4ff2-858e-c4dda2fb42a7
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:26 544ba5871ee259083f18357368
X  12474 drwxr-xr-x     0      0     32768  6-Dec-2015 18:26 MSI3fed1.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:30 b15c67ff-ce87-4e4d-8ae6-8023489756b0
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:30 9e6af300b0f4db59c0c4b227f89a36
X  12477 drwxr-xr-x     0      0     32768  6-Dec-2015 18:30 MSI808df.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:36 _806149_
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:36 1938cd47831f848c25e8
X  12600 drwxr-xr-x     0      0     32768  6-Dec-2015 18:36 MSIda3e6.tmp
X  12600 drwxr-xr-x     0      0     32768  6-Dec-2015 18:37 MSIda413.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:40 0d7a1b23-e7bb-49e7-a338-b610401d32b4
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:40 20fe110439a6d0f98a
X  12494 drwxr-xr-x     0      0     32768  6-Dec-2015 18:40 MSIda442.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:45 _318847_
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:45 bc7a583fa58f06137e4150a944
X  14185 drwxr-xr-x     0      0     32768  6-Dec-2015 18:45 MSI559cc.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:53 89374023-9763-4c4a-88bb-cf58b63f5cd2
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:53 b1a572d0083091ca0148
X  12488 drwxr-xr-x     0      0     32768  6-Dec-2015 18:53 MSI559db.tmp
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:54 _874366_
X  12134 drwxr-xr-x     0      0     32768  6-Dec-2015 18:54 99d7a7ad9f132e62c87b
X  12134 drwxr-xr-x     0      0     32768  7-Dec-2015 08:33 MSI9a555.tmp
X  12134 drwxr-xr-x     0      0     32768  7-Dec-2015 08:33 MSI9a55e.tmp
X  12134 drwxr-xr-x     0      0     32768  7-Dec-2015 08:33 MSI9a563.tmp
X  12134 drwxr-xr-x     0      0     32768  7-Dec-2015 08:33 MSI9a76e.tmp
X  12134 drwxr-xr-x     0      0     32768  7-Dec-2015 08:33 MSI9a777.tmp
X  12134 -rwxr-xr-x     0      0         4  7-Dec-2015 08:37 DDFC36AF-D567-4D21-B5E7-8A66D3D5C4FF.tmp
X  18681 drwxr-xr-x     0      0     32768  9-Dec-2015 05:50 MSI162bb.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:07 MSI9d56a.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:07 MSI9d5cd.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:07 MSI9d5d5.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:07 MSI9d5dc.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d5e3.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d71e.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d725.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d72c.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d733.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d73a.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d741.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d748.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d74f.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d756.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d75d.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d764.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d76b.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d772.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d779.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d780.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d787.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d78e.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d795.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d79c.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:08 MSI9d7a3.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:09 MSI9d7aa.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:09 MSI9d7b1.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 18:09 MSI9d7b8.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb4970.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb4976.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb497b.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb4980.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb4985.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb498a.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb498f.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb4994.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb4999.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb499e.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49a3.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49a8.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49ad.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49b2.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49b7.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49bc.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49c1.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49c6.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49cb.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49d0.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49d5.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49da.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49df.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49e4.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49e9.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49ee.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49f3.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 22:32 MSIb49fa.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 23:40 MSIb6a0b.tmp
X  26614 drwxr-xr-x     0      0     32768 10-Dec-2015 23:40 MSIb6a11.tmp
X      2 drwxr-xr-x     0      0     32768 19-Dec-2015 10:57 MSI44b44.tmp
X      2 drwxr-xr-x     0      0     32768 19-Dec-2015 10:57 MSI44b4b.tmp
X      2 drwxr-xr-x     0      0     32768 19-Dec-2015 11:00 _SI19465.TMP
X      2 drwxr-xr-x     0      0     32768 19-Dec-2015 11:26 MSI484e9.tmp
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:19 MSI9b79e.tmp
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:19 MSI9b7a5.tmp
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:19 MSI9b7ac.tmp
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:19 MSI9b7b3.tmp
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:20 MSI9b7ba.tmp
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:30 MSI4084d.tmp
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:31 _346819_
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:31 1f764225a587ada8ebf6ec8ced3d45f3
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:38 _772701_
X  10241 drwxr-xr-x     0      0     32768  1-Jan-2016 12:38 43f5f414d8f0551a8aac5d63
X  12292 drwxr-xr-x     0      0     32768  1-Jan-2016 12:38 _SI40854.TMP
X  10411 drwxr-xr-x     0      0     32768  9-Jan-2016 13:32 MSI8b732.tmp
X  10411 drwxr-xr-x     0      0     32768  9-Jan-2016 13:50 MSI907d1.tmp
X  12488 drwxr-xr-x     0      0     32768  9-Jan-2016 14:21 MSIa9713.tmp
X  12488 drwxr-xr-x     0      0     32768  9-Jan-2016 14:21 AI_RecycleBin
X  12488 drwxr-xr-x     0      0     32768  9-Jan-2016 14:32 MSIad1b6.tmp
X  12488 drwxr-xr-x     0      0     32768  9-Jan-2016 14:32 AI_RecycleBin
X   2216 drwxr-xr-x     0      0     32768  1-Feb-2016 19:54 MSI80d3d.tmp
X      3 drwxr-xr-x     0      0     32768 12-Feb-2016 06:59 _535705_
X15073283 drwxr-xr-x     0      0         0 12-Feb-2016 06:59 df8955cee1a5fddd3249b80fa4f2af2e
X15075200 drwxr-xr-x     0      0         0 14-Feb-2016 18:16 New folder
X15075200 drwxr-xr-x     0      0         0 14-Feb-2016 18:16 _ELME
X   4003 drwxr-xr-x     0      0     32768 16-Feb-2016 18:01 MSI1e487.tmp
X   4003 drwxr-xr-x     0      0     32768 16-Feb-2016 18:01 MSI1e48e.tmp
X   4003 drwxr-xr-x     0      0     32768 16-Feb-2016 18:02 MSI1e494.tmp
X  20994 drwxr-xr-x     0      0     32768 24-Feb-2016 21:16 _160357_
X14045698 drwxr-xr-x     0      0         0 24-Feb-2016 21:16 7ae082acec30fa290ec3af
X  20996 drwxr-xr-x     0      0     32768 27-Feb-2016 08:00 MSI2f4bd.tmp
 15926074 drwxr-xr-x     0      0         0 22-Mar-2016 00:28 Audiobooks
X     11 drwxr-xr-x     0      0     32768 26-Mar-2016 12:40 MSI3e3bb.tmp
X     11 drwxr-xr-x     0      0     32768 26-Mar-2016 12:41 MSI3e54b.tmp
X  23408 drwxr-xr-x     0      0     32768 27-Mar-2016 19:28 MSI510e4.tmp
X  23408 drwxr-xr-x     0      0     32768 27-Mar-2016 19:28 AI_RecycleBin
X  23408 drwxr-xr-x     0      0     32768 27-Mar-2016 19:50 MSI9538e.tmp
X  23408 drwxr-xr-x     0      0     32768 27-Mar-2016 19:50 AI_RecycleBin
X  23408 drwxr-xr-x     0      0     32768 27-Mar-2016 19:50 MSI953e9.tmp
X  23408 drwxr-xr-x     0      0     32768 27-Mar-2016 20:26 MSI2be7f.tmp
X  23408 drwxr-xr-x     0      0     32768 27-Mar-2016 20:29 MSI2be82.tmp
X  23408 drwxr-xr-x     0      0     32768 27-Mar-2016 20:30 AI_RecycleBin
X  23408 drwxr-xr-x     0      0     32768 28-Mar-2016 09:42 MSI9252e.tmp
X  23408 drwxr-xr-x     0      0     32768 28-Mar-2016 09:42 _SI92593.TMP
X  23408 drwxr-xr-x     0      0     32768 28-Mar-2016 10:18 MSI6aab3.tmp
X  23408 drwxr-xr-x     0      0     32768 28-Mar-2016 10:18 AI_RecycleBin
X  23408 drwxr-xr-x     0      0     32768 28-Mar-2016 10:27 MSI6aab9.tmp
X  23408 drwxr-xr-x     0      0     32768 28-Mar-2016 10:28 AI_RecycleBin
X   2131 drwxr-xr-x     0      0     32768  4-Apr-2016 01:24 _699262_
X   2131 drwxr-xr-x     0      0     32768  4-Apr-2016 01:24 0aa9940b99288696cb6c46
X   2333 drwxr-xr-x     0      0     32768  5-Apr-2016 21:02 _695936_
X   2333 drwxr-xr-x     0      0     32768  5-Apr-2016 21:02 3aa4044b1371e0be5d7b07
X     24 drwxr-xr-x     0      0     32768 19-Apr-2016 19:45 MSI3e477.tmp
X     24 drwxr-xr-x     0      0     32768 19-Apr-2016 19:45 MSI3e535.tmp
X     24 drwxr-xr-x     0      0     32768 19-Apr-2016 19:45 MSI3e53d.tmp
X     24 drwxr-xr-x     0      0     32768 19-Apr-2016 19:45 MSI3e546.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:24 MSI2ed8c.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:31 _SI89216.TMP
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:31 MSI2fd97.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:31 MSI2fdfb.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:31 MSI2ffa0.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:31 MSI2ffa7.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:31 MSI2ffab.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:31 MSI2ffd6.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:32 MSI3001c.tmp
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:32 _SI30153.TMP
X  52144 drwxr-xr-x     0      0     32768 23-Apr-2016 22:32 _SI30157.TMP
X    331 drwxr-xr-x     0      0     32768 24-Apr-2016 02:30 MSIe4c31.tmp
X      2 drwxr-xr-x     0      0     32768 25-Apr-2016 20:09 MSIc4de3.tmp
X      2 drwxr-xr-x     0      0     32768 25-Apr-2016 20:09 MSIc4e48.tmp
X      2 drwxr-xr-x     0      0     32768 25-Apr-2016 20:10 MSIc4e4e.tmp
X      2 drwxr-xr-x     0      0     32768 25-Apr-2016 20:10 MSIc4e74.tmp
X   1782 drwxr-xr-x     0      0     32768 28-Apr-2016 20:57 MSI59f6c.tmp
X   3636 drwxr-xr-x     0      0     32768  3-May-2016 20:46 MSIca5a3.tmp
X   3636 drwxr-xr-x     0      0     32768  3-May-2016 20:46 MSIca5bf.tmp
X   3636 drwxr-xr-x     0      0     32768  3-May-2016 20:46 MSIca5c5.tmp
X   3701 drwxr-xr-x     0      0     32768  5-May-2016 21:37 _358247_
X15928949 drwxr-xr-x     0      0         0  5-May-2016 21:37 d47ffe32f14c3ad124efd7dd8f
X   6583 drwxr-xr-x     0      0     32768  5-May-2016 21:37 MSIe263b.tmp
X   6583 drwxr-xr-x     0      0     32768  5-May-2016 21:37 MSIe266e.tmp
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 21:39 eb13d26b-03ac-40d1-aa85-8cd6e93d15b8
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 21:39 9969a38b5aea0855bb97
X  14106 drwxr-xr-x     0      0     32768  5-May-2016 21:40 MSIe269d.tmp
X  14106 drwxr-xr-x     0      0     32768  5-May-2016 21:41 MSIe2a12.tmp
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 21:44 3b53fa4b-7622-4915-af60-3f59b42ed9ca
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 21:44 7eca324db94c584839421a3eb9e6d0
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 21:51 e71dcf04-a3b4-42d0-9768-151812c5eee3
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 21:51 dc998cfe59a75ae7820831e431
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 22:05 88d592a5-0fa6-44db-af96-5424523cb22c
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 22:05 d3216ae55f21674e58db1fc3
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 22:05 _054384_
X   6117 drwxr-xr-x     0      0     32768  5-May-2016 22:05 2d07619dbdc56f33f9c2c528b695
X   8168 drwxr-xr-x     0      0     32768  5-May-2016 22:05 MSI7fe71.tmp
X    927 drwxr-xr-x     0      0     32768  6-May-2016 19:56 MSI39fd9.tmp
X  12606 drwxr-xr-x     0      0     32768  7-May-2016 10:40 1a20f7e6-6bbf-417a-8771-73bfc5206ce0
X  12606 drwxr-xr-x     0      0     32768  7-May-2016 10:40 e23df72d4662d2e994ca23
dir_partition inode=15926074
FAT: cluster=15926074(0xf3033a), pos=1019745579
Directory /Audiobooks
 15926074 drwxr-xr-x     0      0         0 22-Mar-2016 00:28 .
       0 drwxr-xr-x     0      0         0 22-Mar-2016 00:28 ..
 15892796 drwxr-xr-x     0      0         0 22-Mar-2016 00:24 David Weber, Steve White - Starfire 01 - Insurrection
 15883872 drwxr-xr-x     0      0         0 22-Mar-2016 00:24 Stephen Moss - Fear Saga 01 - Fear the Sky
 15878707 -r-xr-xr-x     0      0 169214608 22-Mar-2016 00:22 2015 - Rogue Lawyer_.m4b
 15915617 drwxr-xr-x     0      0         0 22-Mar-2016 00:26 Ernest Cline - Armada A Novel (Unabridged)
   17088 drwxr-xr-x     0      0         0  3-Aug-2014 23:12 Anthony Robbins - Unlimited Power
   15800 drwxr-xr-x     0      0         0  3-Aug-2014 23:08 Change Your Life in Seven Days - The World's Leading Hypnotist Shows You How -Mantesh
   21938 drwxr-xr-x     0      0         0  4-Aug-2014 11:58 Douglas Adams - Hitchhiker's Guide To The Galaxy (Stephen Fry and Martin Freeman)
   18571 drwxr-xr-x     0      0         0  3-Aug-2014 23:10 Warren Buffett's Management Secrets Proven Tools for Personal and Business Success (Audiobook)
    9621 -rwxr-xr-x     0      0  17133998 28-Jun-2015 09:06 how-to-build-a-successful-portfolio-business.mp3
   10144 -rwxr-xr-x     0      0  48927083 28-Jun-2015 09:07 how-to-create-a-successful-portfolio-career.mp3
   11638 -rwxr-xr-x     0      0  37557339 28-Jun-2015 09:06 screw-work-lets-play.mp3
   12785 -rwxr-xr-x     0      0  98772268 28-Jun-2015 08:54 Shift-Happens.mp3
    9458 -rwxr-xr-x     0      0    151671 23-Oct-2011 21:50 Update Linked Accounts.pdf
Write new boot!
file_win32_pwrite(104,3,buffer,63(0/1/1)) write err
Write error: Can't write new FAT boot sector
fat32_boot_sector
FAT32 at 0/1/1
FAT32 at 0/1/1
Bad
Bad
