Partition recovery not found
Mirio
#1 Post by Mirio »
I'm have a old hdd with 256GB with two partition, first is the data and second is recovery partition
With ddrescue i have create an image of disk (3 days to complete it) and when i try to load it on testdisk this is the result:
Testdisk -> Intel Partition -> Analyze
Quick Search:
How i can recovery it?
Thanks
Re: Partition recovery not found
As the partition table is ok, no need to search for partitions.
Run TestDisk, Advanced, Boot, List. You may be able to copy your files.
Mirio
#3 Post by Mirio »
And how make the fullist of file to recovery?
