Resume photorec session Topic is solved
Bigcat21
#1 Post by Bigcat21 »
Hi I tried to resume a photorec session, but it resumes from the same hd where the .ses is not from the hd where to recover the files
The set up is g: the external hd that shows raw and that I am trying to recover the most of the files, an element 4 gb. Then the h: is the other external hd from which I started the first session, and where the files are going after recovery
If I go to h: and the directory where the .ses is, photorec resume the session but checking h: and not g: as when the first session was first launched
Any help will be highly appreciated
Thanks
Davide
Re: Resume photorec session
Edit the photores.ses file with notepad++ or another text editor and check the source device listed at the beginning.
Bigcat21
#3 Post by Bigcat21 »
Thanks modifying the .ses did the trick
Recovering is back in progress
Davide
