all partitions marked as( D) deleted
Bobdissel
#1 Post by Bobdissel »
Nice to have a place with help.
I really appreciate your work.
My son did something with his computer, he had several infections.
Now the following issue took place,, after a long search on the Internet I fond testdisk and used it.
The program fond after deep search 3 nfts and 1 fat 32 entries Al marked as deleted.
How can I recover the disk so it wil work properly in the laptop?
I am afraid to try because the datw is very important.
Thanks for any reaction.
Bob
Re: all partitions marked as( D) deleted
Please copy and paste the testdisk.log file
Bobdissel
#3 Post by Bobdissel »
Thanks for the reply.
Tue Mar 29 19:30:32 2016
TestDisk 7.1-WIP, Data Recovery Utility, February 2016
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Onjuiste functie.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=945336352768
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=53687091200
filewin32_getfilesize(\\.\E:) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Onjuiste functie.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=262146097152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=114324573184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=113143581696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=10487232000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=480704987136
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1CH162, S/N:Z1D4MMXH, FW:CC47
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500830AS, S/N:9QG0353Z, FW:3.AAC
Disk \\.\PhysicalDrive3 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ASMedia AS2115, S/N:6FB00042304102
Disk \\.\PhysicalDrive3 - 500 GB / 465 GiB - ASMedia AS2115
Analyse Disk \\.\PhysicalDrive3 - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/32/33
filesystem size 819200
mft_lcn 34133
mftmirr_lcn 2
HPFS - NTFS 0 32 33 51 30 43 819200
NTFS, blocksize=4096, 419 MB / 400 MiB
FAT32 at 51/30/44
FAT1 : 7006-7598
FAT2 : 7599-8191
Data : 8192-614399
sectors : 614400
cluster_size : 8
no_of_cluster : 75776 (2 - 75777)
fat_length 593 calculated 593
FAT32 at 51/30/44
FAT: cluster=2(0x2), pos=829440
FAT32 51 30 44 89 93 4 614400 [EFI System Partition] [ESP]
FAT32, blocksize=4096, 314 MB / 300 MiB
NTFS at 105/174/6
filesystem size 938876928
mftmirr_lcn 2
HPFS - NTFS 105 174 6 58548 17 29 938876928
NTFS, blocksize=4096, 480 GB / 447 GiB
NTFS at 58548/17/30
filesystem size 36198400
mftmirr_lcn 2
HPFS - NTFS 58548 17 30 60801 80 15 36198400
NTFS, blocksize=4096, 18 GB / 17 GiB
1 P HPFS - NTFS 0 32 33 51 30 43 819200
Your actual partition table is using EFI GPT but you have forced the scan as PC/Intel.
What problem are you trying to fix ? What error do you have ?
Bobdissel
#5 Post by Bobdissel »
oops i didnt know that.
The problem is , that it wont start windows on my laptop.
It says that the bootfile is missing.
The hard drive had some problems with infections and it was real slow.
Then it started to make noise and stopt working.
So i want that it will work properly again.
Bob
Bobdissel
#6 Post by Bobdissel »
So what to do....?
I will scan the disk again for efi/gpt.
