Testdisk 7.1 WIP Geometry error
gold333
#1 Post by gold333 »
I'm trying to recover a primary bootable partition that has turned RAW using Testdisk 7.1 WIP on a single physical hard drive.
The SMART info is Excellent.
I have not written anything to the problem partition yet.
Error background:
I got a 0x0000006b stop saying the bootcache.cat file needs to be deleted in system32/codeintegrity so it can respawn. But I can no longer access the partition to reach this file.
Method:
Testdisk geometry settings is giving me trouble.
This is one of the most common high end HD's (Western Digital Caviar Black 1TB).
It was split into 2 partitions using the Windows 7 installer.
1. An ~800GB partition with the main install (Win-7 64) (unbootable now and in RAW according to diskmgmt.msc.)
2. A ~100GB backup boot partition (Win-7 32) for moments like this when the primary won't boot.
The storage on the 800GB was 139GB free with the rest containing data.
Testdisk says the geometry may be wrong.
Details of the Western Digital Caviar Black 1TB (WDC WD10 01FALS-00J7B) connected via SATA:
My Bios says:
Cylinders 65535
Heads 16
Landing zone 65534
Sector 255
My usermanual says:
user sectors per drive 1,953,525,169
heads/disks 6/3
bytes per sector 512
Testdisk 7.1 WIP says:
Cylinders: 129201 (??)
Heads: 240
Sectors: 63
Sector size: 512
(To my amateur mind 240 or 255 heads is far too much for a HD isn't it, how are so many little mechanical heads going to fit in there?)
Anyhow, I clicked Analyse on the defailt Testdisk 7.1 WIP values and got:
So it is saying the Heads for NTFS should be 255 but Testdisk 7.1 WIP is reading 240.
I then changed the Geometry by leaving everything on default and changing the heads to 255.
I clicked analyse and got this:
I selected Quick Scan
This is while it was scanning:
When it was finished (it is showing FAT16 and FAT32? Both these partitions were NTFS:
After I clicked continue:
Now trying to list the contents of the first partition using P key for List
and the 2nd partition:
Strangely these files appear to be correct.
Anyhow, so I need help here, the Hard drive data is evident, I just need to know what to put into the Testdisk geometry that is correct. I cannot work with 25 permutations which take 6 hours each to Quick Scan.
I know the drive was split into 3 partitions:
-NTFS ~100 MB System reserved
-NTFS ~800 GB Main Win-7 64 partition
-NTFS ~100 GB Backup Win-7 32 partition
This is the Disk management info:
As a test I let Minitool Partition Wizard analyse the physical disk. This is what it found (which I really don't understand). Sure I had Deamon Tools installed on the main (and the backup) partition, but still why on Earth would it identify so many boot sectors???
Here is additional data:
http://www.bleepingcomputer.com/forums/ ... tcachecat/
Re: Testdisk 7.1 WIP Geometry error
Run TestDisk, Advanced, select the partition, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit and restart your computer.
If it doesn't work, please copy and paste the testdisk.log file content.
gold333
#3 Post by gold333 »
Thank you for your help.
Sorry to be pendantic but I want to take the correct steps.
There is a "boot" option if I select advanced:
But there are 3 partitions to choose from. Which do I choose? -> This is a multiboot Windows 7 system and eventhough I have this problem, the bootloader comes on the screen without problem after the BIOS splash screen. (With bootloader I mean the black DOS type screen where you can choose which of your partitions to boot from using the arrow keys. I believe this is the system reserved area? Which is the first partition in this list above.)
The one that won't boot is the 800gb partition which is the second partition in this list above.
PS: Did you read my personal email/private message to you?
PPS: It looks like Testdisk geometry was correct! MiniTool Partition Wizard and EaseUS Partition Master give me the properties of the physical drive and they both listed what Testdisk had listed without needing to change the geometry. (see image below)
gold333
#4 Post by gold333 »
Would a mod please be able to help me?
If acceptable, I will wire EUR50 via paypal if this can be solved.
I can pay half in advance half after success if possible.
If no solution is found I donate the EUR25 for your trouble.
Please help.
gold333
#5 Post by gold333 »
Is anyone here?
gold333
#6 Post by gold333 »
Is anyone here?
I apologise if it is inappropriate to offer financial donations in return for help.
But an answer would be nice.
#7 Post by cgrenier »
To try to fix the partition listed as RAW by Windows, run TestDisk, Advanced, select the 800GB partition, Boot, RebuildBS, List.
gold333
#8 Post by gold333 »
Hi, I did exactly as you said...
I selected the 2nd partition, which although doesn't say 800gb, is that one.
I got:
Upon clicking RebuildBS I got:
After that, clicking LIST I got:
I quit the program and the .log is:
Tue May 31 19:20:36 2016
TestDisk 7.1-WIP, Data Recovery Utility, February 2016
OS: Windows 7 (7600)
Compiler: GCC 4.9, Cygwin32 2004.1
Compilation date: 2016-03-16T08:10:04
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=107339579392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=892757606400
Disk /dev/sda - 1000 GB / 931 GiB - CHS 129201 240 63, sector size=512 - WDC WD10 01FALS-00J7B, S/N:WD-WMATV1397531, FW:05.0
Disk /dev/sda - 1000 GB / 931 GiB - WDC WD10 01FALS-00J7B
Geometry from i386 MBR: head=240 sector=63
NTFS at 0/32/33
heads/cylinder 255 (NTFS) != 240 (HD)
NTFS at 115335/140/29
1 * HPFS - NTFS 0 32 33 13 163 19 204800
2 P HPFS - NTFS 13 163 20 115335 140 28 1743667200
3 P HPFS - NTFS 115335 140 29 129201 40 24 209647616
NTFS, blocksize=4096, 107 GB / 99 GiB
ntfs_boot_sector
NTFS at 13/163/20
filesystem size 1743667200 1743667200
sectors_per_cluster 8 8
mft_lcn 786432 786432
mftmirr_lcn 2 2
clusters_per_mft_record -10 -10
clusters_per_index_record 1 1
Status: Bad
Status: OK
Sectors are not identical.
Incomplete multi sector transfer detected in $MFT.
ntfs_mft_load(): Failed.
rebuild_NTFS_BS
mft at 16
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
New / Current boot sector
mftmirr_lcn 2 2
mftmirr_lcn 2 2
Not an exFAT boot sector.
mftmirr_lcn 2 2
ntfs_boot_sector
NTFS at 13/163/20
mftmirr_lcn 2 2
Status: Bad
Status: OK
PS: This is simply a 3 partition Windows 7 HD.
1. System reserved
2. 800GB Win 7-64 (won't boot)
3. 100GB Win 7-32 (boots)
Maybe we can use the boot record of 3. to boot 2. ?
#9 Post by cgrenier »
In Advanced, select the same partition, choose Boot and BackupBS, confirm, Quit, restart your computer
Run "cmd" (right click run as administrator) and "chkdsk /f M:"
gold333
#10 Post by gold333 »
Hi I did that.
This is the result:
I rebooted into the same (backup partition C:) and ran
chkdsk /f m:
This was the result:
What shall I do now, run deep scan again? or write? repairMFT? Resize partition a little?
This is the testdisk.log:
Sat Jun 4 21:09:43 2016
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 13/163/20
mftmirr_lcn 2 2
Status: Bad
Status: OK
copy backup boot sector over boot sector
ntfs_boot_sector
NTFS at 13/163/20
NTFS at 13/163/20
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
