Damaged 1To HD
Re: Damaged 1To HD
Would it be possible to repeat your diagnose at an intel PC.
It's a lot faster, because disk geometry is different.
In case we could make a normal diagnose also.
Re: Damaged 1To HD
Ok, i'll try to find an Intel PC and I'll keep you informed.
Thank you for the tip
Re: Damaged 1To HD
I relaunched the Rebuild BS on a PC but it's still as much slow. At this rate the command will end in 6 days.
Any clue to speed up the process?
Re: Damaged 1To HD
Just have a normal diagnose using Analyse.
I'll need infos how your disk is listed, after Analyse from your current partition strucur, Quick Search (the result, if quick Search doesn't find something) after Deep Search also.
Hopefully it's successful and faster?
Re: Damaged 1To HD
Here is the result of Analyse:
Quick Search will end in 1 hour
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 15200 255 63
Invalid FAT boot sector
1 P FAT32 LBA 0 32 33 121601 25 24 1953519616
Re: Damaged 1To HD
In your partition table (current partition structur) is a Win7 / Vista-partition.
Vista/Win7-partition are aligned on megabyte boundary.
Intel partition are aligned on cylinder boundary.
Invalid FAT boot sector indicates that your boot sector or file system is damaged.
The partition doesn't use the complete space.
I'd need the infos after quick search.
Re: Damaged 1To HD
Well, the Quick search is not yet finished and I now have "Read error at XXX" at each sector.
It seems the HDD will end in a garbage
I just need to find a way to retrieve data...
Re: Damaged 1To HD
Please check your smart values using Crystal Disk Info portable.
It doesn't need to be installed.
If you experience read errors or testdisk hangs, please let me know as soon as possible.
In case, stop testdisk Quick Search.
Please let me know the percentage of Quick Search.
Can you connect it internally?After he change the HD enclosure the drive is no longer accessible so he asked me if I can recover his data but I'm stuck.
Re: Damaged 1To HD
Here is the result of CrystalDisk, the damaged disk is the Samsung one
CrystalDiskInfo 4.1.4 (C) 2008-2011 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Starter Edition SP1 [6.1 Build 7601] (x86)
Date : 2012/03/04 13:17:34
-- Controller Map ----------------------------------------------------------
+ Intel(R) NM10 Express Chipset [ATA]
- ST9250315AS
-- Disk List ---------------------------------------------------------------
(1) ST9250315AS : 250.0 GB [0-0-0, pd1]
(2) SAMSUNG HM100UI : 1000.2 GB [1-X-X, jm1] (V=152D, P=2338)
(1) ST9250315AS
Model : ST9250315AS
Firmware : 0003SDM1
Serial Number : 6VCN3TQ7
Disk Size : 250.0 GB (8.4/137.4/250.0)
Buffer Size : 8192 KB
Queue Depth : 32
# of Sectors : 488397168
Rotation Rate : 5400 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 4
Transfer Mode : SATA/300
Power On Hours : 57 heures
Power On Count : 364 x
Temparature : 31 C (87 F)
Health Status : Correct
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : 8080h [ON]
AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 119 100 __6 00000C10EF31 Taux Erreur en Lecture
03 _99 _99 __0 000000000000 Temps moyen mise en rotation
04 100 100 _20 00000000016E Décompte des cycles de mise en rotation
05 100 100 _36 000000000000 Nombre de secteurs réalloués
07 _61 _60 _30 000000167062 Taux d'erreurs d'accès des têtes
09 100 100 __0 000000000039 Heures de Fonctionnement
0A 100 100 _97 000000000000 Nombre d'essais de relancement de la rotation
0C 100 100 _20 00000000016C Nombre total de cycles marche/arrêt du disque dur
B8 100 100 _99 000000000000 Transfert des données à travers le cache tampon RAM entre l'hôte et le disque dur ne correspond pas.
BB 100 100 __0 000000000000 Nombre d'erreurs qui n'ont pas pu être récupérés en utilisant le matériel ECC (voir C3)
BC 100 _99 __0 000000000003 Nombre d'opérations avortées en raison de HDD timeout (temps dépassé)
BD 100 100 __0 000000000000 Information réécrite ou réaffectés à une région sûre du disque dur.Cet ID indique le nombre de ces erreurs détectées au cours de la durée de vie du lecteur
BE _69 _59 _45 00001F15001F Température interne sur les disques Western Digital
BF 100 100 __0 000000000008 Nombre d'erreurs résultant de chocs ou de vibrations externes
C0 100 100 __0 000000000003 Nombre de fois que l'armature magnétique a été rétractée automatiquement suite à une coupure secteur
C1 _99 _99 __0 0000000007FF Nombre de fois que la tête a changé de position
C2 _31 _41 __0 000F0000001F Température
C3 _53 _47 __0 00000C10EF31 Temps entre les erreurs corrigées par code correcteur(codage basée sur la redondance)
C5 100 100 __0 000000000000 Nombre de secteurs "instables"
C6 100 100 __0 000000000000 Nombre total d'erreurs incorrigibles d'un secteur
C7 200 200 __0 000000000000 Nombre d'erreurs dans le transfert de données via le câble d'interface
FE 100 100 __0 000000000000 Free Fall Protection = Fonction conçue pour diminuer la probabilité de perte de données en détectant une chute libre du DD.
-- IDENTIFY_DEVICE ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 0C 5A 3F FF C8 37 00 10 00 00 00 00 00 3F 00 00
010: 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 20
020: 36 56 43 4E 33 54 51 37 00 00 40 00 00 04 30 30
030: 30 33 53 44 4D 31 53 54 39 32 35 30 33 31 35 41
040: 53 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
050: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 80 10
060: 00 00 2F 00 40 00 02 00 02 00 00 07 3F FF 00 10
070: 00 3F FC 10 00 FB 01 10 FF FF 0F FF 00 00 00 07
080: 00 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00
090: 00 00 00 00 00 00 00 1F 05 06 00 00 00 48 00 48
0A0: 01 F0 00 29 34 6B 7D 09 61 23 34 69 BC 09 61 23
0B0: 40 7F 00 22 00 22 80 80 FF FE 00 00 FE 00 00 00
0C0: 00 00 00 00 00 00 00 00 59 70 1D 1C 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 50 00 C5 00 32 59 F2 B4
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 1E
0F0: 40 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 29 59 70 1D 1C 59 70 1D 1C 20 20 00 02 01 40
110: 01 00 50 00 3C 06 3C 0A 00 00 00 3C 00 00 00 08
120: 00 00 00 00 00 1F 02 80 00 00 00 00 00 08 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 3C 00 80 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 10 3B 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 15 18 00 00 00 00 00 00 00 00 10 10 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8B A5
(2) SAMSUNG HM100UI
Enclosure : SAMSUNG HM100UI USB Device (V=152D, P=2338, jm1)
Model : SAMSUNG HM100UI
Firmware : 2AM10001
Serial Number : S2GHJ9BZC02446
Disk Size : 1000.2 GB (8.4/137.4/1000.2)
Queue Depth : 32
# of Sectors : 1953525168
Interface : USB (Serial ATA)
Minor Version : ATA8-ACS version 6
Power On Hours : 0 heures
Power On Count : 149 x
Health Status : Mauvais
Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
APM Level : 0080h [OFF]
AAM Level : FE00h [OFF]
01 __1 __1 _51 00000000DC46 Taux Erreur en Lecture
02 252 252 __0 000000000000 Performance général sortie disque
03 _79 _79 _25 000000001922 Temps moyen mise en rotation
04 100 100 __0 00000000000D Décompte des cycles de mise en rotation
05 252 252 _10 000000000000 Nombre de secteurs réalloués
07 252 252 _51 000000000000 Taux d'erreurs d'accès des têtes
08 252 252 _15 000000000000 Performance moyenne des opérations d'accès des têtes
09 252 252 __0 000000000000 Heures de Fonctionnement
0A 252 252 _51 000000000000 Nombre d'essais de relancement de la rotation
0B 100 100 __0 000000000030 Nombre de recalibration
0C 100 100 __0 000000000095 Nombre total de cycles marche/arrêt du disque dur
B5 100 100 __0 0000000006D9 Inconnu
BF 100 100 __0 00000000000C Nombre d'erreurs résultant de chocs ou de vibrations externes
C0 252 252 __0 000000000000 Nombre de fois que l'armature magnétique a été rétractée automatiquement suite à une coupure secteur
C2 _64 _64 __0 001F001F001F Température
C3 100 100 __0 000000000000 Temps entre les erreurs corrigées par code correcteur(codage basée sur la redondance)
C4 252 252 __0 000000000000 Nombre d'opérations de réallocation (remap)
C5 _21 _21 __0 000000002668 Nombre de secteurs "instables"
C6 252 252 __0 000000000000 Nombre total d'erreurs incorrigibles d'un secteur
C8 100 100 __0 000000000000 Nombre total d'erreurs à l'écriture d'un secteur
DF 100 100 __0 000000000030 Nombre de fois que la tête a changé de position
E1 100 100 __0 0000000000E7 Temps de cycle de chargement/déchargement
000: 00 40 3F FF C8 37 00 10 00 00 00 00 00 3F 00 00
010: 00 00 00 00 53 32 47 48 4A 39 42 5A 43 30 32 34
020: 34 36 20 20 20 20 20 20 00 00 40 00 00 04 32 41
030: 4D 31 30 30 30 31 53 41 4D 53 55 4E 47 20 48 4D
040: 31 30 30 55 49 20 20 20 20 20 20 20 20 20 20 20
060: 40 00 2F 00 40 00 02 00 02 00 00 07 3F FF 00 10
070: 00 3F FC 10 00 FB 00 00 FF FF 0F FF 00 00 00 07
090: 00 00 00 00 00 00 00 1F 1F 06 00 00 00 4C 00 40
0A0: 01 FF 00 28 74 6B 7F 69 61 23 74 68 BC 41 61 23
0B0: 40 7F 00 71 00 71 00 80 FF FE 00 00 FE 00 00 00
0C0: 00 00 00 00 00 00 00 00 6D B0 74 70 00 00 00 00
0D0: 00 00 00 00 60 03 00 00 50 02 4E 92 03 F7 A3 AF
0E0: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 40 1C
100: 00 21 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 3F 00 00
1A0: 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 15 18 00 00 00 00 00 00 00 00 10 1F 00 00
1D0: 00 00 00 00 00 01 04 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 A5
Re: Damaged 1To HD
Your harddisk doesn't look to be in a good shape.
Don't stress it as much anymore.
In some cases, it solved issues.
If it doesn't make any difference, you can try to create an image file on another intact drive using testdisk / Advanced / Image Creation.
Infos;
http://www.cgsecurity.org/wiki/Media_Image
Can you remove it from enclosure and connect it internally to have another check using crystal disk info.After he change the HD enclosure the drive is no longer accessible so he asked me if I can recover his data but I'm stuck.
Infos;
